Right placement for the oil return and feed lines
Old Nov 7, 2003 | 07:00 AM
FOrSfEd's Avatar
Default Right placement for the oil return and feed lines
Pics would be great, I just want to make sure mine is right don't want to blow any seals.
Thanks
lee
Old Nov 7, 2003 | 07:19 AM
Flamenco-T's Avatar
Default Re: Right placement for the oil return and feed lines (FOrSfEd)
example...
or youc an go to my site, http://www.fast-turbo.com/oilreturnassembly.html for more detailed instruction..
thanks
stan
Old Nov 8, 2003 | 08:52 AM
FOrSfEd's Avatar
Default Re: Right placement for the oil return and feed lines (Flamenco-T)
Thanks stan
Old Nov 21, 2003 | 06:57 PM
TurboTeG4's Avatar
What about the oil feed line which way does it go, should the adapter that connects to the oil feed be facin towards the block and then run it down from there underneath.
Old Nov 21, 2003 | 07:39 PM
Flamenco-T's Avatar
Default Re: Right placement for the oil return and feed lines (TurboTeG4)
the adapter for the oil feed line should face straight up and you can attach the feed line from there.
check the pics from my instruction sheet to my customer..
stan
D3LSLO
Mar 21, 2004 08:20 PM
eg6_lsi
Mar 18, 2004 04:46 PM
PrecisionH23a
Jun 16, 2002 07:53 PM
