After rebuild?
Old Nov 9, 2003 | 07:55 PM
ARACER25's Avatar
Default After rebuild?
Well I been babying it but there is a knock that I am not sure about and I am getting a code 67. Not sure what it means but it says Catalyst system efficiency below threshold. But the knock is a problem.
Old Nov 10, 2003 | 10:05 AM
ARACER25's Avatar
Default Re: After rebuild? (ARACER25)
Ok well I still have this knock after the rebuild and I am not sure where its coming from but I think its in the bottom end. So I drain the oil and pull the pan, pickup tube and tray. Everything inside looks good but there was some shavings in the oil and it was pretty dark for only 50 miles also in the oil pan there was what looks like dirt, chuncks, if you rub it between your fingers it breaks apart. I don't really want to pull the bearing caps again to look at the bearings but I guess that is my only option. Any suggestions would help.
Modified by ARACER25 at 6:50 PM 11/10/2003
Old Nov 10, 2003 | 04:50 PM
ARACER25's Avatar
ttt
ramboPandA
Sep 17, 2018 02:25 PM
raverx3m
18
Jul 31, 2012 10:11 AM
cmamtower
Mar 10, 2010 07:10 PM
ludeboy555
Jan 21, 2004 10:55 AM
