Which darton sleeves???
Old Nov 6, 2003 | 12:30 PM
B17aTrbo's Avatar
New User
Default Which darton sleeves??? and help with build...
ok i am rebuilding the block on my B17 with some nice internals and preparing it to handle around 12-15psi daily and maybe 18 at the track with race fuel...
i have looked on the archives and talked to race engineering (john) and decided on the dartons...my question is...
which set of dartons should i go with?
i don't think i'll need the pro series as my car is a daily driven car and i read that they possibly have issues with dispersing heat on daily driven cars...
there are 3 different "levels," pro, sport, and standard...will the "sport" sleeves be sufficient for my needs??? i understand that tuning is crucial but assuming that is of an adequate level...
so far i went with the Je flat top pistons 9.2:1 compression, crower rods, arp head studs, bottom end gasket set, top end gasket set, timing belt, cometic hi-boost headgasket, anything else i need??? if not the only thing im waiting on is the sleeves once i can get them i can drop off at the machine shop...thanks...corey
Old Nov 6, 2003 | 12:31 PM
tegasaurus's Avatar
Default Re: Which darton sleeves??? (B17aTURBO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B17aTURBO &raquo;</TD></TR><TR><TD CLASS="quote">so far i went with the Je flat top pistons 9.2:1 compression, crower rods, arp head studs, bottom end gasket set, top end gasket set, timing belt, cometic hi-boost headgasket, anything else i need??? if not the only thing im waiting on is the sleeves once i can get them i can drop off at the machine shop...thanks...corey</TD></TR></TABLE>
no way dude, you're going to run a timing belt?! crazY!!11
Old Nov 6, 2003 | 12:33 PM
B17aTrbo's Avatar
New User
Default Re: Which darton sleeves??? (tegasaurus)
you know what im sayin,
Old Nov 6, 2003 | 12:36 PM
DC2R714's Avatar
Default Re: Which darton sleeves??? and help with build... (B17aTURBO)
Why does everyone think this? If they are installed right they shouldnt have any problem with overheating. I run mine (Darton Sleeves Mod3) daily and have never had one cooling issue.
As for the amount of boost you want to run I would consider RS, Benson, or some other open deck sleeve if you are worried about overheating. Personally I think you would be fine with stock sleeves at 12-15psi. Boosted Hybrid does it with his stock GSR block and many others have as well. Its all about tuning and cylinder pressure.
Old Nov 6, 2003 | 12:48 PM
93LSivic's Avatar
Default Re: Which darton sleeves??? and help with build... (DC2R714)
Go with the Darton MOD3's, or Pro's---whatever you want to call them. You will not have any cooling issues whatsoever. Every person I sold them too loves them........oh and the guy above me is one of my customers, imagine that.
Old Nov 6, 2003 | 12:54 PM
DC2R714's Avatar
Default Re: Which darton sleeves??? and help with build... (93LSivic)
Dan's work (93lsivic)
Top Notch
Old Nov 6, 2003 | 01:05 PM
B17aTrbo's Avatar
New User
93LSivic how much can you get me the mod3-pro's for??? the lower the better!!
Old Nov 6, 2003 | 01:08 PM
B17aTrbo's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2R714 &raquo;</TD></TR><TR><TD CLASS="quote">
As for the amount of boost you want to run I would consider RS, Benson, or some other open deck sleeve if you are worried about overheating. Personally I think you would be fine with stock sleeves at 12-15psi. Boosted Hybrid does it with his stock GSR block and many others have as well. Its all about tuning and cylinder pressure.</TD></TR></TABLE>
it's the part about running more boost at the track which would be the reason id want to go with the dartons...i haven't talked to anyone about the RS or the benson so i don't know anything about them...prices??? who sells them???
Old Nov 6, 2003 | 01:11 PM
DC2R714's Avatar
search man this topic has been beatin to death
PINKIE2
Jul 29, 2015 08:44 AM
Deej23
K Series
Feb 17, 2014 05:32 AM
CO_RaceFab
Aug 22, 2011 08:40 PM
yoRt
22
Dec 12, 2008 05:07 AM
B17aTrbo
Nov 17, 2003 11:38 AM
