Turbo car jerkyness
Old Nov 10, 2003 | 08:47 AM
FuzzyGreen's Avatar
Default Turbo car jerkyness
I'm not sure if this is a tuning issue, a clutch issue, or just what it's like when you have lots of power, but what is causing this:
When I'm driving at normal part throttle my turbo goes up to about 0 psi(no vac) and when I let go of the gas and then put in the clutch to shift the car jerks hard as if the engine wants to keep going. What is causing this? Could it be my broken front motor mount (all other mounts are fine) or is this normal for a turbo honda?
It's like putting in the clutch is unhooking the engine from the car like a sledgehammer.
Old Nov 10, 2003 | 08:52 AM
b16ahybrid's Avatar
Default Re: Turbo car jerkyness (FuzzyGreen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuzzyGreen &raquo;</TD></TR><TR><TD CLASS="quote">It's like putting in the clutch is unhooking the engine from the car like a sledgehammer.</TD></TR></TABLE>
Say that ten times fast, then tell me what the hell it means.
Old Nov 10, 2003 | 09:00 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Turbo car jerkyness (b16ahybrid)
mount most likely. Does the shifter move when you do it?
Old Nov 10, 2003 | 09:01 AM
FuzzyGreen's Avatar
uh I meant:
"It's like putting in the clutch is unhooking the engine from the car WITH a sledgehammer."
project civic
Apr 29, 2007 06:21 PM
kixcrx
Jan 13, 2007 01:59 PM
epoch707
Feb 9, 2006 02:23 PM
elitesi8
Nov 23, 2005 05:19 PM
00HatchyTuRbO
24
Feb 13, 2005 02:45 PM
