help with boost leak
Old Nov 7, 2003 | 10:10 AM
smokin rubber's Avatar
Default help with boost leak
While I have only had the car for less then a month, I have already come across a problem that has me stumped.
I was running up to 15# of boost peak, and now am down to 10-12#.
I have checked the intake from the turbo to the tb, and as much of the vacum lines as I can reach. I tighented everything that could be, and checked for air leaks with the engine running.
The boost still builds as it had in the past, but will not normally go past 10#, and when it does peak at 12# it is only for a short while around 4,000rpm.
This is my first turbo car so I really dont know what else to check, there is no boost comtroller, just a rre chip.
Please help.
O and this is the GTX
Old Nov 7, 2003 | 11:31 AM
UltimateTSI's Avatar
Default Re: help with boost leak (smokin rubber)
Take it to a shop for a pressure test.
Old Nov 8, 2003 | 09:35 AM
anything else I can check before I spend money at a shop.
Old Nov 8, 2003 | 10:11 AM
kpt4321's Avatar
Check the turbo too.
You can build your own pressure tester with Home Depot parts.
Ultra EK9
Feb 13, 2011 06:48 AM
accord99power
Sep 8, 2009 06:35 PM
1sic3dr
Aug 11, 2007 03:28 PM
crew08 (girlygirlracer)
Oct 13, 2005 07:58 PM
crucial si
May 31, 2003 08:46 PM
