Why do you need a 3 bar MAP sensor with hondata???
Old Nov 6, 2003 | 09:27 AM
B00stedCoupe's Avatar
Default Why do you need a 3 bar MAP sensor with hondata???
Thats what everybody gets and even Hondata themselves sells them. but Hondata is limited to 28.8psi so why not get a 2 bar map sensor. 2 bar is 29.4psi and cost like $40 less than a 3 bar sensor. I personally wont ever boost past 20psi. so wouldnt a 2 bar map sensor suit me better?
Old Nov 6, 2003 | 09:29 AM
integra_gsr98's Avatar
Default Re: Why do you need a 3 bar MAP sensor with hondata??? (B00stedCoupe)
Because this is how it works from what I understand....
vacuum to 0 = 1 bar
0 - ~14.5 = 2nd bar
~14.6 - ~28 = 3rd bar
Technically to run over 28 psi you would need a 4 or a 5 bar mapsensor depending on what was available and if Hondata had support for it.
Old Nov 6, 2003 | 09:38 AM
Default Re: Why do you need a 3 bar MAP sensor with hondata??? (integra_gsr98)
hmmm, can someone confirm this..
Old Nov 6, 2003 | 09:43 AM
turbo*s2k's Avatar
can you switch to a 3 bar map sensor and drive the car before you get the hondata?
Old Nov 6, 2003 | 09:49 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_gsr98 &raquo;</TD></TR><TR><TD CLASS="quote">Because this is how it works from what I understand....
vacuum to 0 = 1 bar
0 - ~14.5 = 2nd bar
That's correct. Remember that you have to overcome atmospheric pressure first, which is exactly 1BAR. 2BAR = ~28psi, but subtract the atmospheric pressure and you end up with ~14.5psi of MANIFOLD PRESSURE. That's why you need a 3BAR sensor for anything ABOVE 14.5psi of MANIFOLD PRESSURE.
Got it?
Old Nov 6, 2003 | 09:51 AM
Mase's Avatar
Default Re: Why do you need a 3 bar MAP sensor with hondata??? (98CTRCoupe)
just remember fellas, i believe the OEM map sensor stops reading at 11.7 psi. so if you plan on running more than that, then thats when u need a 3 bar.
Finest's Avatar
Default Re: Why do you need a 3 bar MAP sensor with hondata??? (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">can you switch to a 3 bar map sensor and drive the car before you get the hondata?</TD></TR></TABLE>
I don't see why not? As long as you don't go over 2BAR of manifold pressure, it should be okay? I haven't done it personally, so don't quote me on it though...
But logically, it should be fine? The only conflict I can think of is that the 3BAR sensor isn't compatible with the stock Honda ECU? Different voltage output?
Old Nov 6, 2003 | 09:55 AM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe &raquo;</TD></TR><TR><TD CLASS="quote">
But logically, it should be fine? The only conflict I can think of is that the 3BAR sensor isn't compatible with the stock Honda ECU? Different voltage output? </TD></TR></TABLE>
yeah the voltage output is different..i will start but won't idle for **** and then it will die..
Old Nov 6, 2003 | 10:05 AM
turbo*s2k's Avatar
Default Re: Why do you need a 3 bar MAP sensor with hondata??? (espanol)
ok thanks. I was just tyring to get it prepared for when I hit the dyno, but I guess I'll just wait to change it...
Old Nov 6, 2003 | 10:07 AM
espanol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks. I was just tyring to get it prepared for when I hit the dyno, but I guess I'll just wait to change it...</TD></TR></TABLE>
you could get someone to burn a base map chip for you the you could drive the car around town and to the dyno.im me if you need one.
Old Nov 6, 2003 | 11:03 AM
Boostfed's Avatar
New User
If you run a 2 Bar Map Sensor your car will run like crap! I had bought a SUPPOSEDLY GM 3 Bar map sensor from Advance Auto parts and when put on the car it ran LIKE ****! Come to find out it was a 2 Bar map sensor even though it was specifically for a 89 Turbo Trans Am the only vehicle ever equipped witha GM 3 bar map sensor. SO get a 3 Bar map and make sure the Hondata internally is set up for the 3 Bar as opposed to the stock map sensor. Good luck.
Old Nov 7, 2003 | 05:58 AM
T3T495GSR's Avatar
Default Re: Why do you need a 3 bar MAP sensor with hondata??? (Boostfed)
what if you just use the check valve (missing link)?
Old Nov 7, 2003 | 07:43 AM
4U2NV's Avatar
Default Re: Why do you need a 3 bar MAP sensor with hondata??? (T3T495GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3T495GSR &raquo;</TD></TR><TR><TD CLASS="quote">what if you just use the check valve (missing link)? </TD></TR></TABLE>
You can't do this with Hondata because the MAP sensor is what tells the Hondata to add more fuel... The MAP sensor has to be able to read the boost pressure at the TB so it can add more fuel with boost...
Old Nov 8, 2003 | 04:06 PM
redciv's Avatar
missing link if not using hondata
Old Nov 8, 2003 | 07:40 PM
stackz's Avatar
at the jetties fishin'
Community Builder
no, you have to either calibrate the ecu to accept the voltage range from the 3bar sensor or get a hondata pre-programmed for a 3bar.
If you got a hondata progged for a 2bar and tossed on a 3bar...you'd have to re-prog it.
no, you don't want to run a missing link on a 3bar sensor...even though you wouldn't in the first place due to it's physical design...
It's useless to run a 3bar sensor on a setup that will probably never see more than 20-25psi of pressure as you'll always be reading really low on it and the ecu will be compensating for that low reading (yes, even a hondata). You optimally want to be running at the middle of the sensor's reading range thus the 2bar would be better for that.
Old Nov 9, 2003 | 08:47 AM
coupey's Avatar
so id be fine using my stock map sensor on say 8psi?
Old Nov 9, 2003 | 09:15 AM
stackz's Avatar
Community Builder
Default Re: (nine nine si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nine nine si &raquo;</TD></TR><TR><TD CLASS="quote">so id be fine using my stock map sensor on say 8psi?</TD></TR></TABLE>
I do all day long...
Either use your stock map sensor with a greddy blue box
OR
get a missing link and run whatever else you want such as a vortech fmu, etc
Old Nov 11, 2003 | 06:12 PM
JSJ EG6's Avatar
Default Re: (stackz)
where can i get the gm 3 bar map sensor for cheap?
also anyone have a DIY on how to wire it up???
thanks
Old Nov 11, 2003 | 06:48 PM
mos's Avatar
mos
Default Re: Why do you need a 3 bar MAP sensor with hondata??? (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">
It's useless to run a 3bar sensor on a setup that will probably never see more than 20-25psi of pressure as you'll always be reading really low on it and the ecu will be compensating for that low reading (yes, even a hondata). You optimally want to be running at the middle of the sensor's reading range thus the 2bar would be better for that.</TD></TR></TABLE>
Look above and read integra_gsr98's post. At 20-25 psi of boost, you would *not* be o.k. using a 2bar.
And IIRC the stock map sensors stop reading accurately after 9.5-10.5psi depending on model... not to say you can't run more. But you probably shouldn't.
Old Nov 16, 2003 | 03:14 PM
B16CRXT's Avatar
Default Re: (TEAM JSJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAM JSJ &raquo;</TD></TR><TR><TD CLASS="quote">where can i get the gm 3 bar map sensor for cheap?
thanks</TD></TR></TABLE>
DITTO ANYONE????
Old Nov 16, 2003 | 03:41 PM
zip's Avatar
zip
Default Re: (CRX TypeR)
http://www.GMpartsdirect.com
http://www.hondata.com/3barinstall.html
turboef90
Feb 3, 2009 04:19 PM
boostek9
Nov 6, 2007 09:49 AM
BigMoneyP
Sep 9, 2005 02:22 PM
BoOsTiN Dc2
Apr 1, 2004 11:17 AM
-iLLuZioN-B18C1
Sep 18, 2003 11:08 AM
