Rdiator fluid problem with FI!!!!!HELP!!!!
Old Nov 6, 2003 | 12:03 PM
Spoonvtec's Avatar
Default Rdiator fluid problem with FI!!!!!HELP!!!!
What could cause to my reserve tank fluid to boil and the temperature to raise when is turbo timed. when it drives it runs fine , but once i stop and it being turbo timed it just does it. please any imput by all means help. thank you
Old Nov 6, 2003 | 12:05 PM
Tinker219's Avatar
Default Re: Rdiator fluid problem with FI!!!!!HELP!!!! (Spoonvtec)
radiator fan turn on?
Old Nov 6, 2003 | 12:26 PM
Spoonvtec's Avatar
yes the radiator fans work.
Old Nov 6, 2003 | 12:28 PM
Tinker219's Avatar
Default Re: (Spoonvtec)
are you full, coolant wise?
Old Nov 6, 2003 | 12:34 PM
Spoonvtec's Avatar
coolant its full, i empty the reserve tank as someone told me and still does it.
Old Nov 6, 2003 | 01:57 PM
Johnyquest's Avatar
Your radiator cap is probably shot. Same thing hapepend to me. Get a new one. The spring is probably weak / dying.
Old Nov 6, 2003 | 02:02 PM
Spoonvtec's Avatar
ok i'll try that asap you might be right because i had to change my radiator because it blew and the cap with the srping and all that stuff was messed up too and i was dumb enough to put it on again like it was. thank you
anyohter imput is welcomed
Old Nov 6, 2003 | 04:44 PM
pornstarSR's Avatar
thermostat not opening....
its mostly a radiator problem because it runs fine untill you stop, and if the fan comes on then its probably your cap....check it
slartibartfast
Jul 1, 2008 11:10 AM
94civicsindy
Oct 2, 2006 09:19 PM
94eg!
14
Sep 13, 2006 04:19 PM
bey
May 22, 2003 02:23 PM
BoostedD15B7
Jul 3, 2002 05:26 PM
