Getting My Car Dynoed, Anything I Can Tune?
Ok I'm getting my car dynoed in two days, here's the current setup
1995 Acura Integra LS (B18B) Non-Vtec
Engine Modifications
Precision T03/T04 Turbo
TurboSmart Wastegate (35mm)
SRP Manual Boost Controller (7psi)
Inline Pro Turbo Manifold
Precision Pro Intercooler
Greddy Type-S Blow Off Valve
Vortech Fuel Management Unit
Walboro 255lph In-Tank Fuel Pump
Aluminum Piping
Turbo Blox Missing Link
Custom Racing Downpipe
Custom Straight Pipe
Ractive Muffler
OBX Breather Filter
OBX Intake Filter
NGK Spark Plugs- One Step Colder
10W30 Mobile One Synthetic Oil
Stock B18B (LS) Internals
B&M Sport Short Throw Shifter
Energy Suspension Shifter Stabilizer Bushings
Prothane Motor Mount Inserts
-Driver & Passenger Side Mounts
I have no air/fuel controller, or boost controller. So I was wondering what, if anything, I could tune. If not, then cool.
Anyone care to make a guess at what my car will dyno? HP and Torque Specs.
Winner will get a Haha
Aluminum Piping
Ractive Muffler
OBX Breather Filter
OBX Intake Filter
Re: Getting My Car Dynoed, Anything I Can Tune? (tegunderpressure)
i didnt think you could do that with an FMU? dont you buy them with the diapraghm value you need in it? FPR's you can adjust though.
i ♥ my honda
Global Mod
Global Mod
Re: Getting My Car Dynoed, Anything I Can Tune? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote">i didnt think you could do that with an FMU? dont you buy them with the diapraghm value you need in it</TD></TR></TABLE>
That is what I thought
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bukbukintegra »</TD></TR><TR><TD CLASS="quote">
You got a boost controler right there??
You really cant tune **** with out any magement system.
Just static fuel press if you have an AFPR like the B&M or aem unit. Thats about it
If you are obd1 and are on a budget just get urberdata and pull some timing and massage the fuel a little bit if you cant affort injectors. Maybe some dirt cheep prelude injectors will give you a bit more control
Some FMU's are adjustable - others arent.
And how come you say you have no boost controller - but then you list it in your mods?
Dont worry about tuning - jus tmake sure its running right with proper AF #s.
Good luck
Good luck
Re: (Drag_On)
the vortec FMU is not adjustable. cartech is however. I hope your air fuel curve is better than that guy who posted his FMU'd car a few weeks ago. scary stuff
you have quite a few mods there but nothing really to control them all..look into hondata, uberdata, AEM EMS, or any other fuel management systems before hitting the dyno because it will save you money in the end because you wont have to go back...
Re: Getting My Car Dynoed, Anything I Can Tune? (bukbukintegra)
O yea that's right I do have the manual boost controller set at 7psi. I meant the electronic boost controllers that can control gear specific boost levels and other options like that. The boost controller i have is set and 7 and will boost to 7psi and hold. So i will be doing my dyno runs all at 7psi. Unless I can get my hands on some c16 or 101 octane and above. By the way do you reccomend turning up the boost with 92 octane pump gas and a bottle of octane booster? Say maybe up to 10-11psi? And about the FMU, it is a Vortech Fuel Management Unit, it does have a little hex screw on the top, but does it really need adjustment? I do not have a Fuel Pressure Regulator, so no adjustments there.
Ahh, I guess that could be. Both the ones I had were, JR and the Vortech SFMU. Both via the diaghrams and the adjustment screw.
Re: Getting My Car Dynoed, Anything I Can Tune? (ccfries)
I hope to break 200 HP, and at least 180 Torque, but we'll see how it goes, the dyno is tommorow. I'll be posting the charts here tomorrow night.
bukbukintegra
07-10-2004 05:34 AM
9SECQTR
04-21-2004 03:21 PM
Talon12bp
02-08-2004 11:01 AM
turbocivic22
11
01-11-2004 10:57 PM
4doorturbo
12-19-2003 05:52 PM
