Is this vac line OK for a bov?
Old Aug 2, 2004 | 12:19 PM
DC_andrew's Avatar
Default Is this vac line OK for a bov?
In this picture, the line that goes from the middle of the valve cover to the intake mani, I beleive is for the PCV valve. My question is...would this be a suitable vac line to T for the bov vac source?
Old Aug 2, 2004 | 12:23 PM
tgreaves's Avatar
Default Re: Is this vac line OK for a bov? (DC_andrew)
I dont see why not.. But I would just "T" into the vacuum lines that you have for your fmu and all that..
Old Aug 2, 2004 | 12:27 PM
G
sh!t happens.
Default Re: Is this vac line OK for a bov? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">I dont see why not.. But I would just "T" into the vacuum lines that you have for your fmu and all that..</TD></TR></TABLE>
yep that is what i did...or buya vaccum box for 30bucks.. hell or make one.
DC_andrew's Avatar
That isnt actually my engine bay, just a pic I used for an example. I cant decide whether I should T the vac line for the FPR or the PCV valve (for the vac source for the bov). Any opinions?
Old Aug 2, 2004 | 12:33 PM
tgreaves's Avatar
Default Re: (DC_andrew)
Get a vacuum block.. Their really cheap or you can build your own.. Then tap into a large vacuum source like somewhere on the intake manifold or the brake booster line..
Old Aug 2, 2004 | 01:47 PM
gritsak's Avatar
Default Re: (tgreaves)
i wouldnt use more then one T off the FPR, and if so make it close, not having to run the line all the way across the engine bay...there should be another nipple somewhere on the intake you can use (cant remember) or just get/make a vacume box like others suggested.
Old Aug 3, 2004 | 05:45 AM
tgreaves's Avatar
Default Re: (gritsak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gritsak &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt use more then one T off the FPR, and if so make it close, not having to run the line all the way across the engine bay...there should be another nipple somewhere on the intake you can use (cant remember) or just get/make a vacume box like others suggested.
Good point.. With long lines and alot of splitting your fpr is going to respond to pressure changes alot slower.. I would just get the vacuum block and call it a day..
Old Aug 3, 2004 | 05:47 AM
DaX's Avatar
DaX
Loved
Community Favorite
My mcmaster vacuum block cost me maybe $25 to make.
Old Aug 3, 2004 | 08:07 AM
LBR92DA-T's Avatar
my friend t'd most of his vacuum lines off from one another and by the time he got to his wastegate the vacuum pressure was so weak.. i redid it from the brake booster hose.. i would say just get a vacuum manifold..
v.i.gsr
Jul 13, 2011 04:09 PM
ericstambaugh07
Apr 8, 2007 10:54 PM
LSEGHATCH
Oct 29, 2005 04:25 PM
vet_girl
Dec 22, 2003 06:21 PM
