60mm gauge in 52mm pod fitment
Has anyone successfully fit a 60mm gauge into the 94-01 Integra Autometer bezel? To be more specific I am trying to find out if the Defi BF oil pressure gauge would fit into one of the pods with a little dremel work.
TIA
TIA
Re: 60mm gauge in 52mm pod fitment (9psiTurboSI)
Thanks for the reply. Is there anyone else who has made it fit into the replacement bezel for an Integra?
Re: 60mm gauge in 52mm pod fitment (FredoSP)
I was searching some of the archives and I came across a thread where someone had issues. I guess the 60mm gauge was too deep and didn't fit within the a-pillar pod. I was just wondering if this is still the case with the bezel instead of the a-pillar gauge pods.
Re: 60mm gauge in 52mm pod fitment (iiilgsrlll)
Should be fine its easy to check anyway... I put a black sock over my gauge to hold it in works good.
Re: 60mm gauge in 52mm pod fitment (turbozxi)
The DEFI gauges are pretty thin if i remember correctly. Ive fit 60mm greddy gauges in 52mm pod and they're pretty deep. You could Use a dremel, Die grinder, etc.. I ve done it with nothing but a file before, its not to hard to do.
They should fit pretty easily
jdm jedi
10-04-2002 06:40 PM
