Boost was fun while it lasted.
Old Jul 31, 2004 | 09:11 PM
tub_sephiroth's Avatar
Default Boost was fun while it lasted.
I finally got my car turbo setup all done. Checked for leaks, everything checked out except for a little exhaust leak at the downpipe. Set the afc, got on the freeway and punched it in 3rd. Vtec never kicked in. Fuel cut off at 7k rpm. Tried it again and my charge pipe fell off and ran over it on the freeway. Went back and got it and the pipe was bent. Have to wait again for another pipe to made. It was fun for 10 secs.
Old Aug 1, 2004 | 01:21 AM
CalGSR99's Avatar
Default Re: Boost was fun while it lasted. (tub_sephiroth)
HAHAHAHHAAH, keep up the good work
Old Aug 1, 2004 | 01:22 AM
CalGSR99's Avatar
You should get your pipes C-notched at a muffler shop. They wont fall off in the future.
Old Aug 1, 2004 | 01:43 AM
honda9369's Avatar
that sucks
Old Aug 1, 2004 | 02:45 AM
Rod.'s Avatar
Default Re: Boost was fun while it lasted. (honda9369)
...bad day
Old Aug 1, 2004 | 06:15 AM
Oyvind Ryeng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CalGSR99 &raquo;</TD></TR><TR><TD CLASS="quote">You should get your pipes C-notched at a muffler shop.</TD></TR></TABLE>
How is C-notching done? Any pics?
Old Aug 1, 2004 | 06:18 AM
B18C1CYA's Avatar
Default Re: (Oyvind Ryeng)
i think he ment beaded ? or flared
Old Aug 1, 2004 | 06:22 AM
mildly.interesting's Avatar
believe me, this is the 1st of many b00st issues for you...good luck!
Old Aug 1, 2004 | 06:36 AM
SynTeg's Avatar
Get steel braided oil lines if you dont already.. I used a rubber hose for my return line and it expanded after a month and then kinked causing my seals on the turbo to blow. Now im n/a for a while.
Old Aug 1, 2004 | 07:05 AM
solowerks's Avatar
thats proly one of the funiest boosting problems ive heard
Old Aug 1, 2004 | 08:17 AM
AspectIndustries's Avatar
Default Re: (solowerks)
How the hell you run over your charge pipe? Looks like you blew two couplings off? O_O Dont be cheap, get some t-bolt clamps and clamp that sucka in. Works gOod for me.
Old Aug 1, 2004 | 10:11 AM
Sohc Driver's Avatar
Default Re: (synik)
funniest boosty boosty problem i've ever heard.....
Old Aug 1, 2004 | 11:58 AM
JforJonathan's Avatar
Default Re: (synik)
damn man that sucks. but you make it sound funny how it lasted for 10 sec. hahaha
Old Aug 1, 2004 | 12:08 PM
ludermark's Avatar
Default Re: (JforJonathan)
the **** we have to put up with when we run boost
Old Aug 1, 2004 | 12:13 PM
alpha's Avatar
Do it right do it light do it wrong do it long Live and learn
Old Aug 1, 2004 | 05:54 PM
Default Re: (SynTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SynTeg &raquo;</TD></TR><TR><TD CLASS="quote">Get steel braided oil lines if you dont already.. I used a rubber hose for my return line and it expanded after a month and then kinked causing my seals on the turbo to blow. Now im n/a for a while.</TD></TR></TABLE>
I do have steel braided oil lines. Well, I was on the freeway and I heard a clunck, then looked at my side rear view mirror and ran it over. This morning I had to start my car to move it and I notice the check engine light was on. It was code 71 (misfiring in cylinder one). The check engine light didn't come on yesterday. My autometer a/f is reading lean as hell. Yeah, yeah.... autometer a/f is just a light show, but does this mean anything? I did a compression check and it reads 210 across the board. Reset ecu and check engine hasn't come on yet, though I haven't driven it and won't til I get a new pipe.
Old Aug 1, 2004 | 06:01 PM
Irishweird00's Avatar
Banned
Default Re: (tub_sephiroth)
Old Aug 1, 2004 | 06:02 PM
turbo*s2k's Avatar
it happens to all of us at one time... Just back on that horse, and try it again...
Old Aug 1, 2004 | 06:03 PM
Default Re: (Irishweird00)
I'd hit it.
Old Aug 1, 2004 | 06:06 PM
Banned
haha my bad... I thought it was funny... I feel ya man, my turbo setup has been one big headache... I just ripped my mounts apart cuz they were never designed for 300horse... and a number of other things to boot... good luck
Old Aug 1, 2004 | 06:17 PM
booscivic's Avatar
Sorry to hear that at least is fixible
Old Aug 1, 2004 | 06:44 PM
hulkhb's Avatar
Default Re: (booscivic)
Hope you did some sort of tunning before you "punched it". next you'll see a rod punch through your block. Becarfull and do it right. Get some T bolt clamps too.
Old Aug 1, 2004 | 08:51 PM
GS-Rdriven's Avatar
damn...
Old Aug 1, 2004 | 09:18 PM
PureTeg420's Avatar
uhh, if you have parts falling off your car within the first day of being boosted...maybe you should have someone who has experience with turbo kits go over your work. It's one thing to blow a charge pipe off one end, but to completely have it drop and run over it....well you obviously didn't clamp either end very well. I am using the cheap clamps that came with my drag kit for 3 years with no pipes being blown off.
Old Aug 1, 2004 | 09:26 PM
m R g S r's Avatar
Couple questions.
VTEC never switched over, why not? Your boosting with the car not fully warmed up, or is there a problem causing it not to switch over.
So it's an LS/VTEC motor, with fuel cut at 7k rpm?
