Does Vacuum tubing thickness matter?
I have some rubber vacuum tubing on my BOV right now (soft, I can squish it with my fingers). I'm getting that fluttering sound everytime I let off the gas (mabye compressor surge?). I'm trying to find out if the thickness of the vacuum line makes a difference. The vac line off the TB where my BOV is T-eed into it much thicker so i'm thinking of getting some of that if it will help.
Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO »</TD></TR><TR><TD CLASS="quote">So does size matter or what? </TD></TR></TABLE>
ask any girl that and she will probably say yes it does..
but in your case no i dont think it does...
Re: (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">maybe you need to adjust the spring on the bov</TD></TR></TABLE>
I'm using a 1G DSM BOV
Re: Does Vacuum tubing thickness matter? (MiraiZ)
I used to use thin rubber line, It like those clear line for fish tank and you can squeze it. After the car is hot, i get weird BOV sound like soemtime i hear it blow off 2 time. The problem was the line was suck in by the vaccuum. so you need a line that hard, and wont suck together...
Re: Does Vacuum tubing thickness matter? (StolenTeg)
good quality rubber vac hose is the way to go. Napa has good stuff that will definatly not crush even under 40+ in/hg vac. they have like 5 aizes by the foot.
I hate colored hose but I have seen one or two brands of silicon hose that might be good. Several of the cheapie hose brands do not impress me as far as wall stiffness.
Re: (T-RO)
do dsm bov use a gasket? my friends greddy type S flutters because he had silicone gasket and it didnt flush flat to the bov flange causing a slight leak.
I did notice after more testign that I THINK the BOV is blowing off more often now (a good thing). I mean it blows off at less throttle than before.
