Oil Pressure
Old Aug 1, 2004 | 03:48 AM
Rod.'s Avatar
Default Oil Pressure
What happens if I run with the stock oil pressure sending unit unplug. I have a oil pressure gauge and that big fat oil pressure sending unit has to go somewhere. I have the ls vtec firewall kit, that has my oil feed,vtec head feed,my line coming out the back of the block and my stock oil pressure sending unit out the other end.
Now I was wondering how do I make the big unit work? Thanks
Old Aug 1, 2004 | 07:01 AM
dennis's Avatar
Default Re: Oil Pressure (redturbocivic)
YOu're just going to have to add another 1/8npt T - and you can run both - no biggy. You can also just unplug the stock sensor and I don't think you'll get a code. Don't quote me though. I run both.
Old Aug 1, 2004 | 07:13 AM
Muckman's Avatar
Moderator in Chief
Default Re: Oil Pressure (dennis)
The oil light circuit is normally open and to close the circuit and activate the oil pressure light, the pressure has to dip below like 5psi or something stupid low. Another words you can unplug the stock sender and no oil light.
I just run a Defi sender and no oil light. And actually even tho the Defi instructions said their sendor threads were 1/8" NPT I didnt need the BSPT adapter, mine screwed right in without problem. The BSPT adapter did not screw in easily.
Old Aug 1, 2004 | 08:26 AM
Rod.'s Avatar
Default Re: Oil Pressure (Muckman)
basically your saying just unplug my stock sending unit from my oil distribution box. Just put my oil pressure gauge sending unit in that spot? Everything would be all set?
Old Aug 1, 2004 | 08:34 AM
T-RO's Avatar
Yep, unplug OEM sender unit and hook up your gauge. Just read youre gauge and youre set
Old Aug 1, 2004 | 01:20 PM
Rod.'s Avatar
Ok, now I taken off the stock sending unit,put it on the side and replaced with the oil pressure gauge unit. Would that wire that use to go to the stock sending unit make my car throw a code???
Old Aug 1, 2004 | 01:30 PM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">And actually even tho the Defi instructions said their sendor threads were 1/8" NPT I didnt need the BSPT adapter, mine screwed right in without problem. The BSPT adapter did not screw in easily.</TD></TR></TABLE>
That's because the thread pitch is the same but the BSPT threads are rounded, not sharp like NPT threads. IOW, the BSPT should be harder to screw in, but it is also more secure.
Old Aug 1, 2004 | 06:16 PM
Rod.'s Avatar
Default Re: Oil Pressure (beepy)
Any know if my wire that goes to the oil sending unit unpluged would pop a check engine light?? I have my sending unit to my gauge in there
Old Aug 2, 2004 | 10:53 AM
Muckman's Avatar
Moderator in Chief
For the second time, NO!
sirtef9
Engine Machining & Assembly
Jun 8, 2017 04:56 PM
shrirag
Apr 11, 2007 09:55 AM
BACKintheDA
Jul 12, 2005 01:05 PM
PatrickGSR94
Dec 19, 2004 07:45 PM
96b18c
Feb 23, 2003 10:45 PM
