Tuning A/F when not in Boost
Old Jul 31, 2004 | 05:50 PM
turtle-eg's Avatar
Default Tuning A/F when not in Boost
I know that in boost, a/f should be around 12:1, but how about when not in boost? I know, at steady vacuum (crusing) we would want 14.7:1, but how about when you're accelerating lightly what should the a/f be at? Someone told be just to tune everything that's in vacuum to 14.7:1 and 12:1 in boost. True?
Old Jul 31, 2004 | 05:56 PM
nevin's Avatar
depends on the load on the motor. Say 100% load (WOT) you would want 12:1 and 10% load (crusing) is 14.7-15.1, then if your accelerating half throttle with moderate load you might want it around 13.5. Depends mostly on the load and if your in boost. Hope this helps.
Old Jul 31, 2004 | 06:38 PM
turtle-eg's Avatar
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">depends on the load on the motor. Say 100% load (WOT) you would want 12:1 and 10% load (crusing) is 14.7-15.1, then if your accelerating half throttle with moderate load you might want it around 13.5. Depends mostly on the load and if your in boost. Hope this helps.</TD></TR></TABLE>
How would you determine load? With the map sensor values?
Old Jul 31, 2004 | 07:00 PM
Mase's Avatar
Default Re: (turtle-eg)
this has been covered in quite some detail numerous times....i think if you searched a little, you'll find a lot of useful info. and if you come up empty handed still, ill release some more info to your liking
aalb1
Nov 15, 2005 02:09 PM
theblkrascal
Oct 27, 2005 06:48 AM
B16Civic93
Jul 13, 2005 02:12 PM
pip9
Sep 14, 2004 02:29 PM
92-h23a1
Aug 7, 2003 08:40 AM
