re-using rings... already searched
Old Aug 3, 2004 | 01:18 AM
tegasaurus's Avatar
Default re-using rings... already searched
k, before you hit that reply button and say i didn't search hoooold yer fire matey!
I am assembling my short block of b16 pistons on an ls/vtec (probably going to see a 35 shot of teh nawz). All went well with the first 3 rod/pistons, and on the last one, the far bottom oil rail/ring slipped between the ring compressor and the top of my sleeve, so when i started tapping it down, i bent it a little bit. note: the busted ring isn't the mesh looking squiggly one, its the bottom of the 2 that go on top/bottom of it.
I was wondering if i could use an old one of those. I would never re-use a top or 2nd ring, but the 3rd doesn't really relate to compression and the ability to keep oil out of the combustion chamber durring combustion, does it?
sorry for rambeling, but here's the cliff notes
can i re-use one of the rails on the bottom ring (#3) for a freshly honed/new motor?
Old Aug 3, 2004 | 04:59 AM
turbosi03's Avatar
Default Re: re-using rings... already searched (tegasaurus)
dude the title of this thread made me believe it was a newbie question... but it turns out to be interesting
bump for some answers
Old Aug 3, 2004 | 06:38 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: re-using rings... already searched (turbosi03)
I think you'll be fine. I would certainly do it.
Old Aug 3, 2004 | 06:40 AM
DaX's Avatar
DaX
Loved
Community Favorite
I would at least check the gap on the ring/rail that you are going to re-use and make sure that it's still in spec.
Old Aug 3, 2004 | 10:49 AM
tegasaurus's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">I would at least check the gap on the ring/rail that you are going to re-use and make sure that it's still in spec.</TD></TR></TABLE>
well that's the thing, there isn't a gap spec on that ring i don't think.
thoughts?
Old Aug 3, 2004 | 11:54 AM
tegasaurus's Avatar
bumpy
Pullig
Jul 27, 2014 06:34 AM
Stock@$$GSR
Feb 19, 2006 05:37 PM
93supercoupe
Jan 16, 2005 07:33 AM
N20civicB18
Oct 25, 2004 06:55 AM
