Nitrous on b18a1
Old Aug 1, 2004 | 07:38 AM
redrex's Avatar
Default Nitrous on b18a1
right now im running 10.0cr(forged pistons) and crower 403's i was lookin to run a 75 shot dp....ill need fuel pump and injectors right?? And i was wondering if anyone else was spraying on 403's how is it?
Old Aug 1, 2004 | 10:18 AM
mekkis's Avatar
Default Re: Nitrous on b18a1 (redrex)
I've a friend with B18A1 large port ('92 DA) with eagles/wisecos, 9:1 CR. He sprays a 100 shot on it with the 402T's, pulls our friend Walter's 65 Mustang w/ Roots blower slightly from a roll... the Mustang's dyno'd at 380-ish whp @ 6 psi. For a 3000 lb (guesstimation) Muffstank, that's a pretty good showing.
I don't know the particulars of Adam's nitrous setup, but he's a friendly guy, would probably chat you up on the phone about it. IM if interested, if you don't get better info here.
Old Oct 21, 2014 | 09:09 AM
CaptainBuster's Avatar
I'm not spraying on 403's but stock valve train built block b18a1 in a half gutted ek hatch. 9.5-1 comp. I'm spraying 100 shot single efi nozzle. stock injectors, stock fuel pump and i'm still running a little rich on them. Pulled my buddies euro r prelude by a landslide. I would like to build my head with 403s in it but I heard to get the full effect of the cams you need higher comp then what I am running.
Old Oct 21, 2014 | 09:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I have an B18B1 powered EF hatch scheduled on the dyno for tuning on the evening of 10/22. It has PR3 pistons, 62403 cams and a dry direct port NOS system. Obviously, it has the necessary supporting mods to make it work properly... an Intake manifold with big fuel injectors and I/H/E. I will post results after we finish.
91integraLSVTEC
Sep 29, 2007 12:42 PM
WhiteLS
Sep 21, 2003 11:34 AM
b18c-93
Feb 14, 2003 11:05 AM
toEknEEg
Dec 22, 2002 01:01 AM
EFing8
Jun 3, 2002 09:50 PM
