How will the weather affect boost?
Old Jul 31, 2004 | 09:23 AM
86si's Avatar
Default How will the weather affect boost?
If it is hot and humid will your turbo be limited to how much boost it can produce?I was getting almost 23psi,(the car hasn't been ran for a couple months)and now i am maxxed out at 20psi.
Old Jul 31, 2004 | 09:27 AM
MachAF's Avatar
Default Re: How will the weather affect boost? (86si)
hot air = less dense = boost gauge won't read as high. but then the waste gate shouldn't be seeing as high of pressure and opening later.
the wastegate should compensate for this and allow the turbo to boost more.
So I think you still should see 23 psi.
Old Jul 31, 2004 | 09:34 AM
m R g S r's Avatar
23psi on a d16, nice!
Old Jul 31, 2004 | 09:37 AM
B18C1CYA's Avatar
you are right about the weather the air is to thin to make alot of boost, but with the wastegate staying shut i dont think it would matter because your car will run like crap, read my post about my weather problem https://honda-tech.com/zerothread?id=943769 i think we have the same problem and is weather related, i drove my car today and it was still humid but it ran better.
Old Jul 31, 2004 | 09:55 AM
86si's Avatar
Default Re: How will the weather affect boost? (MachAF)
my boost controller is turned all the way up.The wastegate doesn't see boost.the turbo is only capable of 23psi
Old Jul 31, 2004 | 10:19 AM
B18C1CYA's Avatar
but if there is no air to compress you will not boost as high, hi humidity = less air, which has alot of water vapor in it btw.
Old Jul 31, 2004 | 10:21 AM
86si's Avatar
Default Re: How will the weather affect boost? (B18C1CYA)
b18muoio
Jul 17, 2011 01:53 PM
justinCO
May 20, 2009 06:11 PM
builtboostedteg
Apr 5, 2006 05:19 PM
B18badboy
Jan 13, 2004 08:06 PM
B_1_8_hatch
Oct 6, 2003 12:01 AM
