Anyone got InlinePro IC Piping&Precision Intercooler 600hp???
Wondering if anyone has this installed I do and doesn't fit for me very well. I have an inlinepro SS manifold,GT3255E, Inlinepro IC piping and the Precision 600Hp intercooler my problem is where it goes from the IC to the turbo that pipe is a tight fit like making literally put the intercooler on the ground almost. So any 94-01 integras or 96-2000 civics I'd appreciate if someone has pictures this would help out alot thanks............................
Yes I have the setup on my b16. Everything fits perfect, the only thing I had to do was grind the down the block.
I have the same if not similar kit on my teg. for the intercooler we cut the front bumper guard (the huge rectangular piece of steel) and used that are to mount the intercooler. as for the intercooler piping, everything pretty much fit. as for the clearance between the block and the turbo, you have to grind the block down a bit to fit the turbo. hope this post helps!
can you take pictures for me cause I was out until 1am lastnight and i got the pipes to fit but the intercooler sits like 2" below the metal bumper support which would mean it would be on the ground. I need pictures just from the connection from the IC to the Turbo if you cut anything or did you remove the power steering cooler pipe thing thats just behind the IC. And I just need directions things you might have did that I'm not doing.............................................
Are you trimming the actual bumper(the metal rectangle)? If you are not trimming it, yea, the intercooler is going to be on the ground.
The only problems or changes i had to do was cut my bumper support so the intercooler sits higher, grind part of the passenger side frame down and cutting a hole in the plastic splash gaurd. Here are some shitty pics...
Yea it's on my teg, but the pics on the civic are pretty much the same. you see how he cut into the metal bumper support. you suspend the intercooler with whatever hardware it came with in between the two ends. i didn't have to drill any holes into the splash guard or anything for the piping. but yea, it's pretty much the same setup as on the civic.
