HELP!
Old Jul 31, 2004 | 02:17 PM
si tuner's Avatar
Default HELP! Car not running right
So i have a 2000 civic si and i just finished installing the rev-hard turbo kit. I also did the walbro fuel pump, rc 550cc injectors, and the hondata s200 w/boost. The car will start but it seems to be running extremely rich, bogging, and seems like it will stall. I need to drive it to get tuned soon, so what should i do? I thought about taking out the injectors for the drive down and installing them once down there. Tell me what you think is the problem and what you would do.
Old Jul 31, 2004 | 02:22 PM
Bulldogg83's Avatar
Default Re: HELP! Car not running right (si tuner)
how far of a drive is it?
Old Jul 31, 2004 | 02:24 PM
si tuner's Avatar
Default Re: HELP! Car not running right (Bulldogg83)
It is about an hour drive.
Old Jul 31, 2004 | 02:37 PM
si tuner's Avatar
What do you think, would you take the injectors out and put the stock back in for the drive down or what else would you recomend?
Old Jul 31, 2004 | 03:25 PM
Bulldogg83's Avatar
honestly I would just run the stock injectors until you got there. It only takes 10-15 mintues to change the out anyways, so might as well be on the safe side and than just change them when you get down there. Just be easy on it when you drive.
96redgsr
Jul 21, 2004 09:46 PM
Street Ghost
Jul 11, 2004 04:58 PM
Total'd GSR
Jan 31, 2002 06:40 PM
jamal-188
Oct 10, 2001 12:03 PM
GSRrR
Oct 3, 2001 03:18 PM
