WBO2 for cheap
Old Jul 29, 2004 | 09:12 PM
beepy's Avatar
Default WBO2 for cheap
I'm not advertising anything for profit, but I have been searching for an inexpensive wideband sensor and controller for a while.
On Ebay the things seem to sell for $200 used. Even the DIY kits can be expensive, and are generally huge. I have seen another one offered on this site for $320.
But after browsing many sites, I found this one that sells a very small, compact controller for a steal: $105. With sensor is $275.
TwinTec.com
The controller is the smallest I have seen, and I like that it has a calibration potentiometer. This display is going to replace the stupid LCD clock in my Rio.
Now I just need to find a cheap L1H1 or L2H2 sensor. I think I can get a used one since the controller is adjustable! (Free air calibration)
Old Jul 30, 2004 | 09:21 AM
beepy's Avatar
Default Re: WBO2 for cheap (beepy)
A question on sensors:
The LAF sensor that comes in the Honda Insight is an L2H2, right?
Old Jul 30, 2004 | 02:01 PM
buckfittyone's Avatar
thats a hot deal.does that use the sensor fron the civic cx?
Old Jul 30, 2004 | 02:08 PM
beepy's Avatar
Default Re: WBO2 for cheap (buckfittyone)
CX? I don't know. I know the L1H1 was used on the '93-'95 VX, or 1.5 VTEC. I also read on the website that the L2H2 (same sensor, different harness) is used on the Insight, and I want to confirm this because I may be able to get a brand new one for a song if it is true.
I just couldn't pass up a $105 wideband controller. **** DIY.
Old Jul 31, 2004 | 12:46 AM
yah im gettin down is
Old Jul 31, 2004 | 06:28 AM
Bailhatch's Avatar
interesting. I have an L1H1 right here along with a displayless diywb controller i built. Maybe this would be a better solution than trying to figure out the diywb display. it looks like a nightmare to me...
make sure you post up your impressions once you try it out. comes with 3day shipping too I have been using a PLX m300 lately and it's exactly what I would want for datalogging other cars but this one looks like it would be good to keep permanatly installed.
Old Jul 31, 2004 | 06:34 AM
RICE POLICE SIP's Avatar
Default Re: WBO2 for cheap (Bailhatch)
tight yo! What exactly is the wide band o2 for?
Old Jul 31, 2004 | 08:09 AM
drvfast's Avatar
Default Re: WBO2 for cheap (Split Image Prez)
To monitor yor air fuel
Old Jul 31, 2004 | 08:46 AM
XDEep's Avatar
Default Re: WBO2 for cheap (drvfast)
call me when they support the $50 bosch sensor..
Old Jul 31, 2004 | 10:00 AM
beepy's Avatar
Default Re: WBO2 for cheap (XDEep)
They also have another unit on the site that supports the LSM4 and datalogs. But it is much more expensive.
Old Jul 31, 2004 | 11:18 AM
Prelude91siT's Avatar
does this wideband use the same harness as the ones found in hondas? if so i might have to jump on this and go to a u wrench it place and snag one
Old Jul 31, 2004 | 03:09 PM
tyrone27's Avatar
Default Re: (Prelude91siT)
can't you wire it to a bosch wide band sensor. I mean a wide band sensor is a wide band sensor. so it shouldn't give off bad reading.
Old Jul 31, 2004 | 03:39 PM
beepy's Avatar
Default Re: (tyrone27)
I have asked that question before and have never gotten a good answer. Honestly I don't know if an L1H1 and a cheap Bosch have the same "lambda graph".
If they did, I would figure there would be adapters on the market, but I have never seen one.
Old Jul 31, 2004 | 11:54 PM
XDEep's Avatar
Default Re: (beepy)
they are not the same. they usually require separate controllers. i forget which one, if any, support both in the same unit.
Old Aug 1, 2004 | 04:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">To monitor yor air fuel</TD></TR></TABLE> I know they are to monitor your air fuel ratio but what's the differance between the wideband and your stock one?
Old Aug 1, 2004 | 04:25 AM
EE_Chris's Avatar
The stock O2 sensor is like a light switch that has a trip point of 14.7:1 a/f ratio - below this value it puts out ~.1v and above this value it puts out ~.9v. Completey useless other than to let you know when you're below 14.7:1 and thats not exactly a ratio you wanna be at when your boosting.
A wideband produces a discrete voltage value depending on the a/f ratio.
Hondata's tech article on the WBO2
Old Aug 1, 2004 | 06:37 AM
Default Re: WBO2 for cheap (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">The stock O2 sensor is like a light switch that has a trip point of 14.7:1 a/f ratio - below this value it puts out ~.1v and above this value it puts out ~.9v. Completey useless other than to let you know when you're below 14.7:1 and thats not exactly a ratio you wanna be at when your boosting.
Hondata's tech article on the WBO2</TD></TR></TABLE>
Oh cool, thanks
Old Aug 1, 2004 | 06:46 AM
ILLICON3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XDEep &raquo;</TD></TR><TR><TD CLASS="quote">call me when they support the $50 bosch sensor..</TD></TR></TABLE>
Old Aug 1, 2004 | 08:07 AM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">They also have another unit on the site that supports the LSM4 and datalogs. But it is much more expensive.</TD></TR></TABLE>
ya it supports the bosch and its $425. definitely not worth that. the plx m500 for $490 is wayyy better.
Old Aug 1, 2004 | 10:12 AM
mekkis's Avatar
I get the feeling the L1H1 sensor unit is being discontinued... that's why the LSU4-based unit, with the sensor that costs $125 less, is still commanding a premium.
Might be a good buy for someone wanting a display, or who has a method of taking WB controller output and datalogging it seperately as needed.
Old Aug 1, 2004 | 12:30 PM
beepy's Avatar
Default Re: WBO2 for cheap (mekkis)
The L1H1 is actually sold as a Bosch branded part now. I doubt it will be discontinued because honda still uses it (the L2H2) in the Insight. (I confirmed this)
I still think it is a great deal. If I look hard enough I am sure I can get a sensor for cheap.
Old Aug 1, 2004 | 01:41 PM
civictypenos's Avatar
i have a freind who bought the twin tec unit,ill let you know how well it works out,he paid $250 for it shipped off ebay from twin tec.i persoanlly bought a techedge diy kit,took a while to get it up and going.i had a palm logger and all the trimings.had about $450 invested into it with logger,display and sensor.worked great.
Old Aug 2, 2004 | 12:31 PM
Default Re: WBO2 for cheap (civictypenos)
i checked with autozone and they sell the compatible bosch unit for $150 but im sure i can still find a used one for a better deal from a junkyard.are there any other vehicles besides the 93-95 vx and the insight that uses the l1h1 or l2h2 sensor? i heard the civic hx uses the sensor also but i could be wrong, can anyone clear this up?
Old Aug 2, 2004 | 02:29 PM
XDEep's Avatar
ya hx uses it also. good luck finding one..
sonno
Engine Management and Tuning
12
Apr 12, 2014 03:05 AM
Maxime
Aug 20, 2007 01:20 PM
Weapon_R
Sep 28, 2004 08:23 AM
graphic
Jan 6, 2004 09:23 PM
