question about tuning
Old Jul 30, 2004 | 02:21 PM
Btothe3rdDegree's Avatar
Default question about tuning
to all you street tuners
how do you tune timing? fuel seems relitively easy, just watch your wideband, but what about timing?
any help would be most appreciated
Old Jul 31, 2004 | 04:42 AM
Default Re: question about tuning (Btothe3rdDegree)
anyone?
Old Jul 31, 2004 | 07:47 AM
99B16Si's Avatar
people will use different methods to determine timing, for instance using .75 degrees retard per pound of boost is pretty common but theres also factors such as compression, fuel octane, turbo size, IAT's, etc that play a role.
Old Jul 31, 2004 | 08:26 AM
boosted_dc2's Avatar
Default Re: question about tuning (99B16Si)
are you tuning on a dyno???
Landon
Old Jul 31, 2004 | 12:30 PM
Default Re: question about tuning (boosted_dc2)
nope street tuning, i'll try .75 degrees per pound
Old Jul 31, 2004 | 01:05 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree &raquo;</TD></TR><TR><TD CLASS="quote">nope street tuning, i'll try .75 degrees per pound </TD></TR></TABLE>
You should get it on a dyno. Cylinder pressures are higher when your motor is making peak torque then they are when you're not at peak torque. If you took your timing values and plotted them out on a graph they should look sinusoidal, like a cosine graph. Start off higher to help spool the turbo, drop down to prevent detonation around the torque peak, and bring some timing back in as you approach redline.
7rrivera7
Engine Management and Tuning
Dec 13, 2016 04:19 AM
booboo782
Sep 20, 2013 12:05 PM
stockb18c
Dec 21, 2008 11:56 AM
ID_ten_T
Jan 20, 2004 07:11 PM
JPP
Mar 20, 2002 05:32 PM
