"Uberdata" goof enough for 450hp+ setup?
Has anyone ever heard or worked with "uberdata" on B16A2?
We are planning to build a 450hp+ setup and often heard to take this program for our injection and ignition? It shall be a very easy program if you take bigger injectors and a 3bar mapsensor (we want to go 24psi).
Or other oppinions?
Thanks
Or other oppinions?
Thanks
Re: "Uberdata" goof enough for 450hp+ setup? (hondaapi)
i dont see why you couldn't. i didnt 360whp on 440cc's on about 12psi, stock map sensor, with my old setup on uberdata untuned. just takes some tuning and understanding of the program.
http://www.ecimulti.org/uberdata
Go there and read up. It is possible provided you have modified your MAP sensor, injectors, etc. to compliment the Uberdata programming.
Re: "Uberdata" goof enough for 450hp+ setup? (Terrabomb)
There is at least one car that has run 400+ and a probably a handfull in the 300s. I tuned a b18a to 321hp and 268 tq with it.
Re: "Uberdata" goof enough for 450hp+ setup? (omahaturbocivic)
Willis tuned uberdata on the Titan motorsports civic coupe. I belive it was in the 420-435 whp range with the old setup. It can be done if tuned right.
Re: "Uberdata" goof enough for 450hp+ setup? (Mad Chemist)
my goal is 300whp stock block on uberdata tuned and eventually a lot more when i'm built
i have a B16a2 and made 326 on 12psi with uberdata, untuned, the program was just a copy of a buddies car we just threw it in, its exactly the same as hondata as far as the set up and map scaling
Combustion Contraption
13
02-14-2005 09:02 AM
