to everyone out there with IHI turbos, post your setups and #'s!
hey guys, pretty soon now im going to be installing my HMT kit and im using the probe IHI turbo. I just wanted to look at other peoples setups and see what kind of numbers (dyno and 1320) that you've got
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup »</TD></TR><TR><TD CLASS="quote">just curious. is IHI a certain design of turbocharger or what?</TD></TR></TABLE>
No, it's a manufacturer, like Garrett, Mitsubishi, KKK, Scwitzer, Holset, Turbonetics etc. etc. They manufacture their own turbos, and are most commonly used in OEM applications like the Subrau Impreza STi (Subaru has always used IHI, including the good, old 1800GL/Leone Turbo). Also, Apexi turbokits comes with IHI turbos. I also *think* IHI turbos are made in Japan.
EDIT: IHI IS Japanese, and "IHI" is short for "Ishikawajima Harima".
Modified by Oyvind Ryeng at 8:53 PM 8/1/2004
Re: (Oyvind Ryeng)
Good to know Now when i tell people what kind of turbo I have, I can say Ishikawajima Harima. Cmon, someone's got to be running this turbo
Re: to everyone out there with IHI turbos, post your setups and #'s! (hatchback_al)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al »</TD></TR><TR><TD CLASS="quote">looks like ill be the only one out there with this turbo, sweet </TD></TR></TABLE>
For a reason...
I might put it on a Go-ped.
For a reason...
Re: to everyone out there with IHI turbos, post your setups and #'s! (tegunderpressure)
personally, for me its a great turbo. spools fast and doesnt put too much strain on the motor, its good to start out with in my opinion. better than no turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al »</TD></TR><TR><TD CLASS="quote">better than no turbo </TD></TR></TABLE>
Good point. And you seem to understand how its going to perform, so more power to you.
I have been looking at this turbo (IHI RHB52) myself as an option simply because my sister's old probeGT turbo is now to the point of pointless to repair.... aparently someone has used this turbo before to the point that there is an adapter flange availible to mount the snail to a vx/hf manifold.
http://www.turbod16.com/viewtopic.php?t=10190
Hope it this helps, I haven't e-mailed the guy soI don't even know if he is still making them. good luck with it, I'm kinda releived to see someone else considering this turbo as well.
Ive got my own kit already all set up, i machined my own plate But if you dont have the resources to do that (i have a metals shop) then pre fabbed ones are the way to go
Re: to everyone out there with IHI turbos, post your setups and #'s! (fuctup)
Do me a favor real quick, check to see if your wastegate actuator pushes or pulls on the wastegate. Thanks.
forums.probetalk.com then go into first gen performance. I believe some of those guys have gone low 13s on the stock turbo - but they are a 2.2 SOHC engine - almost ALL torque.
They are good to about 15 psi on that motor before they become inefficient but the lifespan is reduced at those levels. I believe stock is 11 psi on them. They produce good TQ numbers but fall off greatly above 5k rpms. This could be due to manifold,head etc design. there are some cool upgrades you can do using T Bird and RX-7 parts interally that will make them good to 300 whp with still no lag.
Good turbo for low-mid range D series.
i plan an running the stock boost on my sohc vtec motor with nothing other than maybe some headwork and a small cam, im going to work mainly on getting it tuned right and have it be safe as possible so i can drive in the mountains with it when i move to CO, still need it to be a little ripper though
D16y8 + ihi rbh5 VJ20 of mazda BP 1800cc turbo
440cc DSM injector + resistor box + VAFC Hack
FMIC @7 psi
no number yet but start spooling @ 2700 rpm - Max out abit above 4000 rpm.
it small enough to keep AC
but spooling so fast......good on city ride.....for long ride highway.......ummmm not sure.....
FMIC @7 psi
Re: to everyone out there with IHI turbos, post your setups and #'s! (pramonn)
I have a IHI VF22 from a subaru STI on my zc sohc, turbo is ball bearing so it spools up quite nice and makes good power 245whp on 13psi. Hopefully have the car running again today.
I am personally using an IHI RHC7 turbo on my Built GSR setup, Just got everything in, mounts, fabricated DP, SpoolinPerformance manifold (FITMENT SUCKED *** FYI) ect ect ect. Anyway this turbo is T4, so a bit larger than what you have, but none-the less, IHI. Shooting for 500whp or so, should be fairly interesting power band, this turbo has a 61mm turbine and a 56mm Compressor inducer. Ill post up the dyno graph after my tuning appointment next week. I did a **** ton of looking around at these guys, really NO info at all out there, especially on my turbo. Had to search through the supra/ RX7 forums to find anything, but from what I have seen these are quality turbos, known for their very very strong wheels. Although the cost to repair them is QUITE high, so keep that in mind. Best of luck on your build.
