Uberdata questions
Old Jul 29, 2004 | 04:45 PM
jetpilot's Avatar
Default Uberdata questions
Does Uberdata permit the use of a map sensor larger than stock (3bar??) and large injecotrs like 680cc or more?? I mean does it have a fuel cut defencer so that after the ecu reades boost no cels or lean mode will come up??
thanks
Old Jul 29, 2004 | 05:40 PM
MachAF's Avatar
Default Re: Uberdata questions (jetpilot)
http://www.ecimulti.org/uberdata/
Old Jul 29, 2004 | 05:45 PM
TEZTnTUNE's Avatar
yes it does
Old Jul 29, 2004 | 06:28 PM
GDM Z28's Avatar
Default Re: Uberdata questions (drp_shp_tech)
yes i run a 3 bar and 740cc injectors on a stock LS. Check out the uberdata site..someone runs 1000cc injectors and has them idleing perfectly.
Old Jul 29, 2004 | 09:21 PM
leed's Avatar
Default Re: Uberdata questions (civicflnum1)
Im currently running 86lb deka's. Idle is good and steady, but it likes it rich (high13's/low 14's AF) or it will stumble.
Due to problems with the ECU applying ECT and IAT trims, I would recommend using the smallest injector you can get by with.
Old Jul 30, 2004 | 08:52 AM
Terrabomb's Avatar
Default Re: Uberdata questions (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">http://www.ecimulti.org/uberdata/</TD></TR></TABLE>
Fnix
May 17, 2012 03:04 PM
HondaKid936
Jul 27, 2008 03:53 PM
bewstn ex
Mar 16, 2008 07:01 PM
Quade
Oct 2, 2003 09:57 AM
420aNT
Apr 8, 2003 08:11 PM
