EMS experts please read! Cam sensor info
Old Aug 1, 2004 | 11:50 PM
B16A1-EF9's Avatar
Default EMS experts please read! Cam sensor info
I thought that this would be the best forum to post this in.
I want to run one coil per cylinder. On my EMS I have to run a crank sensor, but to run 4 coils I also need a cam sensor.
I'm going to buy Electromotive's crank wheel and sensor but I can't find anyone that makes a cam wheel and sensor.
Do you guys know of any company that makes one?
If not, can I use the stock distributor and gut it out and only keep one of the sensors in there as a cam sensor? My EMS allows me to change the amount of teeth to look for so I was thinking I might be able to do this. Then I could just make an aluminum cover for the distributor instead of using a cap.
Any help is greatly appreciated guys....thanks in advance!
Old Aug 2, 2004 | 12:16 AM
JDogg's Avatar
Default Re: EMS experts please read! Cam sensor info (B16A1-EF9)
you can use the stock distributor ..... i have done it a few times actually.
we sell a coil on plug kit for the ems ... 600 shipped, includes coils, aem cdi, custom wiring harness, and spark plugs. i will also setup your ems to run the coil on plug setup.
pm me for specific instructions on how to set it up.
jason
Old Aug 2, 2004 | 08:02 AM
B16A1-EF9's Avatar
Default Re: EMS experts please read! Cam sensor info (JDogg)
Coil on plug, by that do you mean you sell coils that fit right on top of the plugs?
I'm thinking of running an MSD DIS-4 with (4) Blaster SS coils.
Has no one heard of anyone making cam wheel and sensor kits for Honda???
Old Aug 2, 2004 | 09:21 AM
revhigh96's Avatar
talk to jdogg, I have been looking into coil on plug and he has a great deal going. and the aem c2di is amazing
Old Aug 2, 2004 | 12:15 PM
JDogg's Avatar
Default Re: (revhigh96)
yea.. coil on plug.. we use 4 motor cycle style coils. they fit right on top of the plugs.. no plug wires at all.
you dont need any extra cam/crank sensors... the honda sensors work fine.
Old Aug 2, 2004 | 10:34 PM
B16A1-EF9's Avatar
Default Re: (JDogg)
Sorry man, when I said EMS I didn't mean AEM. I meant engine management system. I have a DTA ecu. It's an english computer used in many rally race cars, etc. It requires that you use a 60-2 toothed wheel. And when using 4 coils it also requires the use of a cam sensor.
I have the crank wheel but I can't seem to find anyone that makes a cam wheel, thats why I was wondering if using the stock distributor, if I could get that to work.
But thanks.
Old Aug 2, 2004 | 11:49 PM
tony1's Avatar
Default Re: (B16A1-EF9)
We sell a dual pole hall sensor that can be used for cam and crank signal. If your ecu will only recognize a 60-2 wheel then you can't do this hall for the crank signal. If it'll recognize a square wave signal for the cam then all you have to do is use a hall sensor and put a magnet in your cam gear for the trigger. The square wave signal of the hall sensor is a much better signal than the stock magnetic sensor in the distributor. Gimme a call at the shop if you are interested or have any more questions.
Tony
Norwood Autocraft
972-722-2813
Old Aug 3, 2004 | 12:16 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (tony1)
Tony made this trigger wheel for my fluidamper:
I dont have any pics with the pick ups in it tho.
Old Aug 3, 2004 | 12:20 AM
JDogg's Avatar
B16A1-EF9....... ah, when i see ems i think aem ems....'
tony... normal honda aem ems's wont read the halleffect pickup. the daughtor boards are setup for the mag sensor and must be reconfigured to read the halleffect... aem dosnt want normal people doing this... soon as my car gets up and running i'll be giving you a call though
Efabe
Aug 9, 2017 02:59 PM
B18CivicEH2
Apr 14, 2016 06:58 PM
votex5
Jun 14, 2013 11:52 AM
demo024
Honda CR-V & Element
Jan 31, 2011 12:03 AM
B16A1-EF9
Aug 2, 2004 09:01 AM
