Went to the track last night ( I think I broke it )
The track was recently resurfaced, I redynoed my car. Seemed like a perfect opportunity to see what kind of times I could put down. First off I dynoed 247 whp and only 190 ft/lb torque on a stock b18b1 with a custom turbo setup. Running a T3 Super 60 at 10 psi. Traction was a bit of a problem, best time of the night was a 13.6 at 107 mph. I had a 2.5 60'. After a few runs I heard a rattle. Popped the hood and this is what I found:
It was leaking some fluid at the time, it's now dried. I think the mount is shot, I'm pretty sure it's shot. Do you think I can just replace it with another OEM mount with maybe an insert? If I do that, do you think the mount will hold, or would it be better to nut up and get some HASport mounts?
Re: Went to the track last night (ptran13)
Whoa, were you wheel hopping like a ****? I would say it is toast.
If you do a lot of draggin, bet a stiffer mount (not sure who makes them anymore).
I broke the drivers side mount in my B18B EK. The liquid spewed everywhere and the motor literally jumped up and dented the hood. I am replacing all OEM mounts with aftermarket mounts, just haven't decided which brand to go with.
Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 »</TD></TR><TR><TD CLASS="quote">nice times..what kinda car is it in?</TD></TR></TABLE>
93 Civic CX. Its capable of better times if it had a better driver
Re: Went to the track last night (bukbukintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bukbukintegra »</TD></TR><TR><TD CLASS="quote">i'd reccomend prothane motor mount inserts, only because it's working fine for me. </TD></TR></TABLE>
who makes poly inserts for the upper mounts??? i didnt think anybody did.. i would like to get new mounts or inserts for my car as well to help w/ the wheel hop..
thanks
thanks
Re: (tegmech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmech »</TD></TR><TR><TD CLASS="quote">get those 60' times down next time. A little vht works wonders </TD></TR></TABLE>
Believe me, I tried. Everyone was having traction problems, the track was recently resurfaced. There isn't enough rubber on the ground yet.
Re: Went to the track last night (TurboBumblBee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboBumblBee »</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>
nopi has them
nopi has them
Re: Went to the track last night (90ZCREX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90ZCREX »</TD></TR><TR><TD CLASS="quote">
nopi has them</TD></TR></TABLE>
i dont see them on the nopi.com website.. u have a link??
I also am a huge fan of prothane inserts. cheap and very effective.
Re: Went to the track last night (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">liquid? what the hell </TD></TR></TABLE>
yup mine busted and had all this liquid inside .
I have prothane inserts in every mount in my b18b in my integra. My friends can't believe how strong they are. The motor won't even budge, and neither will you wallet at only $60 at summit racing.
you can get that upper mounts insert from prothan, like 40 bux max! it works like a champ, i just did mine yesterday, it comes with 2 inserts "street" or "race" and the race which i used is stiff as ****, lots of vibration.
you will have to press out the steel insert inside your mount, which is NOT easy. you have to lock it in a vice and get an air chissel to push out the steel sleeve
Re: (fl_hmong_racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fl_hmong_racer »</TD></TR><TR><TD CLASS="quote">would the hasport mount be a good substitute?</TD></TR></TABLE>
Yes, I just bought the mount kit for a B into an EK from Full-Race, they were having a kick *** sale on these.
i dont see them on the nopi.com website.. u have a link??</TD></TR></TABLE>
Give NOPI a phone call. Their online cat sucks ***. Thank god the main warehouse is like 5 minutes from my house.
