How can I plug the oil feed hole on the block?
I'm going to rebuild my turbo fix other various things so the turbo kit needs to come off. How I can plug up the block on the back of the block? Can I use like a special size bolt to plug it? If so what size is it? Its for a DOHC ZC. Thanks for the help.
Contact Flamenco-T...I bought a -10AN cap for my oil pan from him to cap off the oil return fitting. I actually had the fitting welded to my pan about 3 months in advance of me installing the kit, and just rode around with the cap on.
I'm not sure if they make -3AN caps...I'd ask Flamenco-T, but worst case scenario, you could take the NPT to AN fitting out and put a 1/8" NPT plug in there which you should be able to pick up from just about anywhere [I ordered a quantity from McMaster...they're what I use to block off the unused ports on my vacuum manifold...same size, 1/8" NPT].
Re: (SynTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SynTeg »</TD></TR><TR><TD CLASS="quote">Thanks, I'll look for a 1/8 NPT plug to put in the back of the block.
P.S. thats one ugly dude on your Avatar </TD></TR></TABLE>
hahahaha... thats him isnt it?
the back of the block is NOT npt, do not use npt to plug the block.
Re: (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">
the back of the block is NOT npt, do not use npt to plug the block. </TD></TR></TABLE>
Yes, it's me in my avatar...it's ok.... I just got really close to the camera in that picture...I'm really not THAT ugly.
Yeah, don't put the NPT plug in the back of your block...I was under the assumption that you had a BSPT to NPT adapter and that you were using a brass tee with NPT fittings. If you use an NPT plug, put it in the tee, where there are NPT threads.
Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony »</TD></TR><TR><TD CLASS="quote">put the oil pressure sensor back in</TD></TR></TABLE>
VTEC-DA
11-30-2002 01:58 AM
