oil pan removal?
Old Aug 2, 2004 | 08:05 PM
AF-b16a1's Avatar
Default oil pan removal?
has anyone had a hard time removing their oil pan? i smacked the crap out of it and still wont break loose from the rtv? anyone got suggestions? its a y7 btw
Old Aug 2, 2004 | 08:10 PM
Chris1091's Avatar
Default Re: oil pan removal? (AF-b16a1)
My b18c1 pan came right off.
Be absolutely certain you're not forgetting any bolts.
Old Aug 2, 2004 | 08:12 PM
quik sol's Avatar
did you take the flywheel cover off and get those bolts?
Old Aug 2, 2004 | 08:32 PM
blackeg's Avatar
Default Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol &raquo;</TD></TR><TR><TD CLASS="quote">did you take the flywheel cover off and get those bolts?</TD></TR></TABLE>
i missed this step the first time i took my oil pan off. just have a friend hold it while you give a "slight nudge" to the side with a rubber mallot
Old Aug 2, 2004 | 08:38 PM
Civility's Avatar
Default Re: (blackeg)
the liquid gasket or whatever honda uses can hold the oil pan pretty well. What i did was i removed all the bolts, hammered it a little bit and then just ended up getting a screwdiver and wedging it in and pry it off. After a while it just popped off.
Old Aug 2, 2004 | 08:39 PM
AF-b16a1's Avatar
thanks i just pryed it i know that wasnt good for the mating surface but freak it man that was on there...oh and i did take off everything...thanks guys
Old Aug 2, 2004 | 09:04 PM
prennro's Avatar
Default Re: (AF-b16a1)
be careful not to overtighten the bolts when you put it back on.....just snug them up.
The GSR pan that was on my swap was freakin cranked down by the dumbass who didnt replace the gasket and thought he would stop a slow pan leak by tightening the bolts as tight as he could. Needless to say, it bent the metal insert and over time started leaking like a SOB.
AF-b16a1's Avatar
Default Re: (prennro)
gotcha have a new gasket for it too
Old Aug 2, 2004 | 09:53 PM
quik sol's Avatar
I ddint replace mine and it hasn't leaked. I didnt overly crank them but I made sure they were tight enough.
lazyxmofo
Mar 9, 2011 06:26 PM
shbrown
Jan 28, 2006 03:46 PM
92civeg
Jan 7, 2004 12:35 PM
Loveless
Apr 23, 2003 04:57 PM
dynomax27
Oct 15, 2002 04:22 PM
