Please, Everybody help me out with my turbocharged Civic
Hello, I own a 1994 Civic Hatchback, I have this problem, my car runs good, not enought thought, it used to run better with a lame manifold, T3 by garret, and smaller injectors and a smaller intercooler, can it be the downpipe ? because my downpipe is 2" that getting 2.5" after like half a meter, something like that, because of the AC, please help me out, ASAP, thanks in advance, Avi.
P.S. these are my specs:
1994 Honda Civic Si
Engine D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
Turbonetics Turbo T3/T04 Stage II Ballbearing
J.E SRP Pistons & Rings
Conrods by Crower
Turbo Exaust Manifold by SSAutoChrome
3 Bar Map Unit
Light Flywheel
Clutch by Clutchmasters
720 CC Injectors by Precision Turbo with Resistor
Walbro Fuel Pump for 7 Bar
Webber Fuel Pressure-Adjustment PR1/3B
Front Big Intercooler
2.5" Boost Pipes
Greddy Type-S Dump Valve
R1 Cone Air Filter
Greddy Profec B Boost Controller
AEM Independence Programmable ECU
BlockGuard by KMS Engineerings
Bigger Radiator
Accel ThunderStorm 300+ 180mm Ignition Wires
NGK Iridium IX Spark Plugs
1994 Honda Civic Si
Conrods by Crower
3 Bar Map Unit
Light Flywheel
2.5" Boost Pipes
R1 Cone Air Filter
Bigger Radiator
Re: Please, Everybody help me out with my turbocharged Civic (T-Charged-Civic)
How much boost are you running? Is the car tuned at all? 720cc injectors are BIG, especially on a car with a 2" downpipe. If I had to guess I would say it's too much fuel unless your making like 450+ hp. It could be a number of things though. I know on my car it turned out to be fuel pressure. Just start messing with it, and only change 1 thing at a time. If it doesn't help, put it back like you had it. It will be easier to pinpoint the problem that way and you can address it accordingly. Good luck, turbo problems SUCK!
Don't believe the rumors
Re: Please, Everybody help me out with my turbocharged Civic (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT »</TD></TR><TR><TD CLASS="quote">Has anyone tuned your car?</TD></TR></TABLE>
Re: Please, Everybody help me out with my turbocharged Civic (crawdad689)
I'm running 1.3 Bar, my car is tuned very good with
a wide band air/fuel ratio, I had a 440 RC Injectors,
still have them, u think they're better for my setup ?
ok, I had an EX, now I own a hatchback,
I had a T3, now I have a T3 T4
I had a lame manifold, now i got better,
I got a bigger intercooler, new plugs,
bigger injectors, everything is better, but the
downpipe, which is smaller, it runs like,
10-15 HP stronger than then.
ej1serge
04-15-2008 08:29 PM
