Where to get reinforced vacuum lines?
Im trying to buy some lengths of vacuum line and I was trying to find reinforced lines. The kind im referring to are rubber with a weaved outer reinforcement. Can anyone help me out? Checked summit but they didnt have them [or i couldnt find them]
Re: (turbotime)
I'm not sure where to get it either, but the vac line in the back of autzone works just fine for a turbo build. I'm using it with no problems
Re: (Chris22215)
I used some of that cheap **** they sell at VIP... Had it running from my Brake Booster -> vacuum manifold. Then from Vacuum manifold -> Wastegate and BOV
As soon as the vacuum line got hot it began to collapse.
After that I used some quality vacuum line that my dad had laying around. If you can bend it easily, it's took weak.
Re: (dunkd)
The local foreign auto part distributor sells the cloth vac hose here. 3mm and 5mm in 3 meter lengths. Go ask a VW place where to get it.
The black nomex stuff would work but its $$$$ and I have never seen it smaller than -4AN.
Re: (Bailhatch)
yea that stuff is reaaallllly expensive, i think geoff has it on his car for the valve cover vent lines and his radiator lines.
what ive used and works pretty well is rubbef fuel lines....its pricey around $3-4/ft biut it works awesome...it just has a very thick wall...so the tubing doesnt collapse under vac....and holds up tot eh heat just fine...
Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">yea that stuff is reaaallllly expensive, i think geoff has it on his car for the valve cover vent lines and his radiator lines.</TD></TR></TABLE>
I just did an oil cooler and PCV system for a customer...$450 in lines and fittings the black with nickle plated ends looks so hot though.
Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">I just did an oil cooler and PCV system for a customer...$450 in lines and fittings the black with nickle plated ends looks so hot though.</TD></TR></TABLE>
yea it does it makes me all hot and bothered
for my vaccum lines i wanted to run all stainless braided, but im running low on funds. so, i went to he hardware store and found that dishwashers and some refrigerators (sp) washinbg machines, etc use stainless braided line. for like 15 bux u can get 8 foot of line and it has weird fittings on the end which i will just cut off and make something else on the end so it looks good. just a thought
I was just messing with the nomex stuff again, Its sort of a pain to cut without fraying...worse than the ss stuff. And its VERY fire proof. I tested it
Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">I was just messing with the nomex stuff again, Its sort of a pain to cut without fraying...worse than the ss stuff. And its VERY fire proof. I tested it </TD></TR></TABLE>
lol, is this the same stuff as the PRO-LITE hose?
