MSD 1000cc injector problem w/ Victor X mani
So I started reviewing some stuff and realized that my injectors are not sitting in the bungs correctly. Take a look....
The base of the injector is hitting the outter part of the mainfold/bung. I am using the OEM rubber gasket that I used with my RC's (that I did not have a problem with).
Has anyone else has this problem with these Bosch type injectors? They are actually MSD injectors made by Bosch I believe....
Re: MSD 1000cc injector problem w/ Victor X mani (tepid1)
I had to use the RC seals with my RC's....the stockers wouldnt seal, from the looks of that photo there is no seals at all but you said there are so I dunno
Re: MSD 1000cc injector problem w/ Victor X mani (96 GSR-T)
The X comes in two different types...
1. For Honda style injectors
2. For Bosch style
Contact Edelbrock and see what they say. I do know the Bosch is a larger dia..
2. For Bosch style
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">I had to use the RC seals with my RC's....the stockers wouldnt seal, from the looks of that photo there is no seals at all but you said there are so I dunno</TD></TR></TABLE>
The seals are 100% in there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WVTURBOCRX »</TD></TR><TR><TD CLASS="quote">The X comes in two different types...
2. For Bosch style
Contact Edelbrock and see what they say. I do know the Bosch is a larger dia..</TD></TR></TABLE>
I was un aware that there are two different types.... can anyone else confirm or deny this?
2. For Bosch style
Re: MSD 1000cc injector problem w/ Victor X mani (WVTURBOCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WVTURBOCRX »</TD></TR><TR><TD CLASS="quote">Sorry about that, I was thinking of there Pro-Flo Fuel Rails.
Yeah now I know what you are talking about.... thanks
Should I stack 1 and a half of these OEM rubber seals? I think Geoff from F-R did something like this....
Bump for some answers....
I'm in the same boat with Siemen 1600cc's, Victor X, and GE fuel rail... Thought about drilling to open the rail up...
Re: MSD 1000cc injector problem w/ Victor X mani (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">I'm in the same boat with Siemen 1600cc's, Victor X, and GE fuel rail... Thought about drilling to open the rail up...</TD></TR></TABLE>
The rail is not my problem.... it is the bung in the manifold that needs to be chamfered (sp?) at just the top of the bung.
Re: MSD 1000cc injector problem w/ Victor X mani (portenio78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by portenio78 »</TD></TR><TR><TD CLASS="quote">Where are your manifold to fuel rail spacers? </TD></TR></TABLE>
In that pic I just had the injectors sitting in the bungs. The rail was not tightened down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by portenio78 »</TD></TR><TR><TD CLASS="quote">those might actually give you the tad bit of space you need?</TD></TR></TABLE>
Are we talking about the same thing here? The rail to manifold spacers will not help in this situitation. I would need a taller injector to manifold rubber o-ring if anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">I just used some DSM seals. They're larger than the hondas. </TD></TR></TABLE>
Where did you get them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">
Where did you get them?</TD></TR></TABLE>
I had them left over from my old DSM 450s. You can get them at a mitsu dealer though.
Re: MSD 1000cc injector problem w/ Victor X mani (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Those look the same as Precision injectors.. Are you using new injector seals?</TD></TR></TABLE>
They are not new, but they are the OEM version seals. They are the origional seals that came with the stock GSR manifold.
Do you have a fix for this?
Re: MSD 1000cc injector problem w/ Victor X mani (Turbocivic94)
do you have the plastic washers that go between the bushing and manifold? I have presisions and they would sit like what you have in the picture without the washer. with the washer in they fit perfect once the rail is bolted down. you can get the washers from the dealer or probably find some at a hardware store
Re: MSD 1000cc injector problem w/ Victor X mani (ramennoodles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramennoodles »</TD></TR><TR><TD CLASS="quote">do you have the plastic washers that go between the bushing and manifold? I have presisions and they would sit like what you have in the picture without the washer. with the washer in they fit perfect once the rail is bolted down. you can get the washers from the dealer or probably find some at a hardware store</TD></TR></TABLE>
I do not have the washers.... I have seen them in pics like this (#4 in the pic)
Is this what you think I need? It would seem to make sense that it would work....
lol, i have the same exact combo (AEM, JG, MSD 1000's)
I'll go take a look when i go home this weekend, AFAIK i didn't have this issue...
and i used OEM honda Orings on top and bottom w/ the fuel rail spacers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 »</TD></TR><TR><TD CLASS="quote">I do not have the washers.... I have seen them in pics like this (#4 in the pic)
Is this what you think I need? It would seem to make sense that it would work....</TD></TR></TABLE>yes, those are the washers I'm talking about. put those in and the injectors won't hit the manifold anymore
