Does JRSC have oil in it?
Re: Does JRSC have oil in it? (APEXI Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEXI Si »</TD></TR><TR><TD CLASS="quote">I was wondering if JRSC have oil in them... if so how and when do you replace it. </TD></TR></TABLE>
Yes they have oil in them and you don't have to change it till 100,000 miles.
you have to take the 10mm bolts off the nose drive and tap the nose drive off nice and straight because there is a plastic coupler in side called a moly gaurd witch joins the nose drive and rotor group together and you dont want to break it.. then go to your local gm or ford dealer and get S/C oil its all the same as oem cars with a eaton rotor group just fill about 4 oz through the allen on the nose drive but dont forget to re seal the parts when putting it back together we use loctite gasket eliminator (pink) good luck sounds like a lot but not really. just a reminder its a whole lot easier to do this off the car
