building a jdmd15b
i just bought a jdmd15b long block from hmotorsonline.com to replace the blown y7 i had suzuki vitaras but i cant use them for my d15 they stick too far out the deck so i bought cp 9:1 pistons .i am going to go with eagle h beams but was wondering which ones to use with my d15b
Part # eg-5394h3d fits:
Honda Civic All Years
is this the part number i use or is there a specific rod for the d15b ? gimmie some info so i can get this **** ordered so i may boost again with the best aight l8ter
Part # eg-5394h3d fits:Honda Civic All Years
the d15b has a completely different rod than any other d series, i believe crower makes rods for it but last i checked they werent off the shelf, custom built and run about 800 bucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devine »</TD></TR><TR><TD CLASS="quote">the d15b has a completely different rod than any other d series, i believe crower makes rods for it but last i checked they werent off the shelf, custom built and run about 800 bucks.</TD></TR></TABLE>Wrong, the d15b rods are the same as the the d16's. You have to worry about the pistons, they have the same compression height as a d17 00-03gx. So you can get aftermarket pistons for that car, but only race engineering makes them using wiseco pistons. People on turbod16 have used the vitraras, and they have NOT stuck out of the block.
this is very interesting, i researched building my d15b a little less than a year ago and found that people were saying a no go on using d16 rods, do you have any links to references so i could touch up my knowledge?
Here's one for starters, you can search for more if you like on the same site, even this site has comparision of the rods done by mista bone. http://turbod16.com/viewtopic....=d15b
hondakid94
Mar 26, 2008 06:09 PM
