Tunner questions look at this map for a sec
Old Apr 25, 2006 | 06:50 AM
JDMCRX's Avatar
Default Tunner questions look at this map for a sec
I know the left bar verticly is the RPM but when u go from left to right is what ??
Old Apr 25, 2006 | 06:55 AM
Race Egr's Avatar
Default Re: Tunner questions look at this map for a sec (JDMCRX)
That is the amount of load on the engine. MBar is vacuam until you get to were it says .5 then that is going into boost
boosted92's Avatar
Top number is just a number denoting which column you're in. As it shows you down at the bottom, the second colum is your reading from the MAP sensor.
Old Apr 25, 2006 | 07:27 AM
JDMCRX's Avatar
Default Re: Tunner questions look at this map for a sec (boosted92)
I know that but i do not understand the units like when im at 6000 rpm and i move over to the right how do i correspond with the PSI like say im at 6000 rpm and 8psi of boost the map would be in the high cam but on the chart were to the far right cause its like mBAR 4.0
Old Apr 25, 2006 | 07:34 AM
JDMCRX's Avatar
Oh i thikn i figured it out lol I moved the chart over this is what i get is the number indicate PSI or ??? The ones highlited in red from 10 to 16
Old Apr 25, 2006 | 07:36 AM
alpha's Avatar
Click on the seperation bar at column 11 and drag it to the right so you can make the table larger.
Old Apr 25, 2006 | 07:37 AM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Oh i thikn i figured it out lol I moved the chart over this is what i get is the number indicate PSI or ??? The ones highlited in red from 10 to 16</TD></TR></TABLE>
You got it. Columns 10 through 16 indicate 0.5PSI to 28PSI.
Old Apr 25, 2006 | 07:42 AM
JDMCRX's Avatar
Default Re: Tunner questions look at this map for a sec (0x64)
Coo now i understand it i did not see the coloums from 11 on cause i could not see them.
Old Apr 25, 2006 | 07:43 AM
JDMCRX's Avatar
Cause if you look at 10 to 16 notice that at 6000 above the map goes down leans out???
Old Apr 25, 2006 | 07:45 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Cause if you look at 10 to 16 notice that at 6000 above the map goes down leans out???</TD></TR></TABLE>
It should lean out a bit on the top end, do you have a wideband on the car? You aren't doing any tuning without one I hope.
Old Apr 25, 2006 | 07:49 AM
alpha's Avatar
As your torque is falling off and/or staying linear
Old Apr 25, 2006 | 08:05 AM
JDMCRX's Avatar
I orig got S30 cause i was tired of the tune. I just slapped some base maps used the EGT gauge to make sure they did not go past 1400 and i drove it all last year when i was in the millitary driving 1500km per weekend. This year im gonna get a Wide Band im looking at the PLX300 so i can tune this thing properly.
Whats a good wide band for the S300 the AEM or the PLX300?
Old Apr 25, 2006 | 08:52 AM
Soccerking3000's Avatar
i have the plx m-300 and love it
Old Apr 25, 2006 | 09:20 AM
nota-eg's Avatar
Default Re: Tunner questions look at this map for a sec (Soccerking3000)
I love my PLX M-300 and I wouldn't trade it for anything else.
ashb82
Engine Management and Tuning
Sep 3, 2009 03:29 AM
rorik
Jan 23, 2006 06:27 PM
Got_soy
Dec 13, 2005 09:34 PM
alexsracing
Nov 22, 2005 01:40 PM
paulzy
Dec 5, 2001 10:04 AM
