good summer coolant/water mixture?
im in tx it gets hot but i wont drive the car when its 95+ outside b/c of no a/c.
so, whats a good mixture of coolant and distilled water?
Re: good summer coolant/water mixture? (warp)
I'm not sure on an exact mixture, probably your standard 50/50, but I know by adding water wetter you have a chance of seeing a decrease in temps throughout the summer. You could also install a high output fan such as FAL.
i run 1 cup of 50/50 coolant 1 bottle of water wetter or purple ice and rest distilled water ... i found that if i used just distilled water and wetter i'd have to top off the coolant bottle once every week.. so i added 1 cup of 50/50 and the coolant kept that from happening.. i daily drive mine boosted gsr with a civic style rad. and use the ac . this is the best i've found so far.. i drained the cooling system totally ( disconect hoses, and heater hoses )
Re: good summer coolant/water mixture? (black98gsr-t)
50/50 or premix prestone as long as every thing else is up to snuff your good to go. thats what i run and every day i sit in traffic for about an hour iat get up to 150deg. while coolant sits at 175deg.
Re: good summer coolant/water mixture? (JDMCRX)
Me and Elspol have played around with water wetter and so forth I found in the CIVIC coolant system. Use distiled water and half bottle of watter wetter and we never had a problem. But then again we do not drive in ur guys heat waves
B A N N E D
Location: Orange County / Palm Springs 714/76hoe, ca, usa
Re: (rudebwoy)
I used 100% water and direct the fan to the power source to keep the fan on no problem with it in 2 years (I know I'm cheap as*) its work great temp won't go up to half line
Re: (spoon95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon95eg »</TD></TR><TR><TD CLASS="quote">I used 100% water and direct the fan to the power source to keep the fan on no problem with it in 2 years (I know I'm cheap as*) its work great temp won't go up to half line </TD></TR></TABLE>
did you know there is a reason why they recomend a 50/50 coolant water mix? its because the coolant has lubricant and anti corosion additives, if you used only only water you shorten the life of your water pump, and corode your cooling system, even though water gives the best cooling.
Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy »</TD></TR><TR><TD CLASS="quote">
did you know there is a reason why they recomend a 50/50 coolant water mix? its because the coolant has lubricant and anti corosion additives, if you used only only water you shorten the life of your water pump, and corode your cooling system, even though water gives the best cooling.</TD></TR></TABLE>
Re: good summer coolant/water mixture? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">100% distilled water here </TD></TR></TABLE>
distilled water and water wetter 50/50 mix works good for me
Re: good summer coolant/water mixture? (Hondatec38)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondatec38 »</TD></TR><TR><TD CLASS="quote">I'd say just all 100% distilled water. Worked great for me.</TD></TR></TABLE>
yup
yup
Re: good summer coolant/water mixture? (nota-eg)
why use anti freeze in summer???
I use either Water wetter and the rest distilled water OR Motul Coolant(Inugel) with water..
nonvtec92
11
04-30-2008 02:45 PM
