leaking boost
Old Apr 22, 2006 | 03:12 PM
jtracing919's Avatar
Default leaking boost
My car doesnt make boost while free reving. When driving it doesnt make boost while accelerating in 1st and jumps to around 5 and bleeds down while accelerating when in second and higher gears. I have a tial 38mm with .5bar spring and an apexi twin chamber bov
Old Apr 22, 2006 | 03:40 PM
The Weather Man's Avatar
Make sure your hose clamps are all tight.
Start the car, and run your hands along the pipes to see where the leak is coming from. Also, make sure your BOV is tight (or welded on).
Old Apr 22, 2006 | 04:45 PM
Targa4Life's Avatar
Default Re: leaking boost (jtracing919)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtracing919 &raquo;</TD></TR><TR><TD CLASS="quote"> My car doesnt make boost while free reving. </TD></TR></TABLE>
Neither does mine but I though this was normal.... I mean my freinds with smaller turbos can but I just figured that it was normal for bigger turbos? Am I wrong?
Old Apr 22, 2006 | 05:01 PM
N20civicB18's Avatar
u wont boost when free revving unless u have a VERY small turbhoe
Old Apr 22, 2006 | 05:12 PM
A.E Motoring's Avatar
Default Re: leaking boost (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">u wont boost when free revving unless u have a VERY small turbhoe</TD></TR></TABLE>
just pretty much in general u wont make boost just by reving the **** out of your car, it needs to be under a load. But try feel around on the charge piping
Old Apr 23, 2006 | 04:52 PM
I've checked all my ic piping and connectors, my bov flange is welded to my pipe and is tight I am gonna try and tighten the spring and see if this helps? I am also gonna try and unhook my waste gate line and darefully see if its opening early for some reason. I have a 57 trim t3/04e. Is it not going to show boost in 1st gear cause it doesnt have as much of a load? I'm begining to go crazy trying to figure this thing out...
niceguysfinishlast
Mar 22, 2008 02:28 PM
B18C_EJ8
Oct 19, 2007 04:53 PM
Boring
Dec 10, 2004 12:41 PM
ktran1
Oct 18, 2004 01:29 PM
NyQuiL
Jul 4, 2003 04:05 AM
