Oil pump........
Old Apr 24, 2006 | 11:38 AM
Mugencrxsir1's Avatar
Default Oil pump........
Is it necessary to upgrade your oil pump? I'm putting the finishing touches on my ls/vtec, so I have ls block. thanks Ls pump, or b16 pump?
Default Re: Oil pump........ (Mugencrxsir1)
I guess what I'm trying to say is, will I be fine with the stock LS oil pump? thanks
Old Apr 24, 2006 | 12:21 PM
Dc4turbo408's Avatar
If u gonna do ls vtec, your best bang is a type r oil pump, or gsr oil pump..... If ur gonna run the ls, theres gonna be some problems.
Old Apr 24, 2006 | 01:24 PM
SL0WEGG's Avatar
Default Re: Oil pump........ (LsvtecBoi408)
what year ls? 96+ b series pumps are all the same
Old Apr 24, 2006 | 06:02 PM
B18C Turbo's Avatar
Default Re: Oil pump........ (boostedej1)
GSR/type r oil pumps are the same. I suggest buying one of these, $100 at my dealer. If you buy a 94-95 gsr oil pump they are $171 and only accept the obd-1 lower timing belt covers. If you go with a 96+ gsr you have to use a obd-2 96+ lower timing cover.
Old Apr 24, 2006 | 06:22 PM
96 GSR-T's Avatar
Default Re: Oil pump........ (B18C Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C Turbo &raquo;</TD></TR><TR><TD CLASS="quote">GSR/type r oil pumps are the same. I suggest buying one of these, $100 at my dealer. If you buy a 94-95 gsr oil pump they are $171 and only accept the obd-1 lower timing belt covers. If you go with a 96+ gsr you have to use a obd-2 96+ lower timing cover.</TD></TR></TABLE>
Umm...... last I checked they are not the same
Old Apr 24, 2006 | 11:52 PM
Default Re: Oil pump........ (96 GSR-T)
how are they the same? gsr and type r oil pump?
Old Apr 25, 2006 | 04:07 AM
SL0WEGG's Avatar
ALL 96+ integra pumps are the same ls/gsr/hype r go check the part numbers. Also including b20's
Old Apr 25, 2006 | 05:39 AM
Muckman's Avatar
Moderator in Chief
Yup 15100-P72-A01
Old Apr 25, 2006 | 02:45 PM
96 GSR-T's Avatar
Default Re: Oil pump........ (Muckman)
I never checked part numbers but I can recall several posts about type-r oil pumps put out slightly more pressure due to their higher redlines and power level etc., guess I was mis-informed
Old Apr 25, 2006 | 03:02 PM
TurboEM1's Avatar
not to thread jack but what pump would be used on an OBD 0 b16a pr3 motor? and how hard is the install? Any links. Thanks
young geezer
Oct 1, 2011 12:21 PM
jdm.fanatic
Dec 8, 2007 05:16 PM
hydroflip
Aug 6, 2007 02:07 PM
astralshadow
Jun 12, 2006 06:38 PM
shawn_crx
Jan 25, 2004 12:34 AM
