Question about Compression numbers
Old Apr 25, 2006 | 11:28 AM
1slowdc2's Avatar
Default Question about Compression numbers
If you have seen my other topic this one is related.
I just got my turboed GSR compression tested and here are the numbers starting from the distributer(left to right).
160,180,200,220
So now that you know this, what does it mean? Could it be a blown headgasket? My car does overheat. If it is my rings, i thought that i should be getting a lower number than 160, like 80 or something. Any suggestion would help.
Old Apr 26, 2006 | 07:50 AM
1slowdc2's Avatar
Default Re: Question about Compression numbers (1slowdc2)
Can anybody help me? Any opinions would be great? At least point me in the right direction.
Old Apr 26, 2006 | 06:59 PM
purpleh22's Avatar
Sounds like bad rings or valves. Even if it were a head gasket you would still need to open it up or replace it.
Old Apr 26, 2006 | 08:27 PM
1slowdc2's Avatar
Default Re: Question about Compression numbers (purpleh22)
Well thanks for the reply. I was starting to think that no one likes me... I guess i'll take pics and post and let everyone know.
Old Apr 26, 2006 | 09:13 PM
loverboy1981's Avatar
YOUR PROBLEM IS A LEAKING HEADGASKET THATS WHY YOUR CAR IS OVERHEATING AND THAT WHY U ARE GETTING DIFFERRENT NUMBERS , BECAUSE IF IT WAS YOUR VALVES OR RING U WOULD PROBABLY GET 40 - 35 - 88 - 110 ECT.... U KNOW... TRY DOING A LEAKEGE TEST WITH A ( LEAKEGE TESTER ) .... GOOD LUCK
Old Apr 26, 2006 | 09:15 PM
komat's Avatar
Default Re: Question about Compression numbers (loverboy1981)
even if the rings were bad
you can still get good compression
i had my ringlands cracked in 4 diff spots
still got perfect compression
Old Apr 26, 2006 | 09:32 PM
dunkd's Avatar
have a leakdown test done. your comression isn't THAT bad.
Unlimitationz
Feb 22, 2005 03:47 PM
boosted lude
Oct 21, 2004 04:06 PM
Josh717
Apr 20, 2003 08:36 PM
foesicks
Jan 8, 2003 03:16 PM
lsvtec42
Dec 6, 2001 12:39 PM
