Gt40r oil feed
i've never seen a 3 an on bigger turbos, i used to run a 4 an on m sc61 without any problems, i would use a 4 an on that turbo, i've seen a 6 an some setups.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">i've never seen a 3 an on bigger turbos, i used to run a 4 an on m sc61 without any problems, i would use a 4 an on that turbo, i've seen a 6 an some setups.</TD></TR></TABLE>
what are you talking about?
-3 is fine..... ball bearing turbos use alot less oil then journal bearing turbos...you can run -4 with a restrictor fitting even with -3 you should run a restrictor.
