Basemap problem or chipped ecu problem? Help needed asap!
Old Apr 22, 2006 | 05:01 PM
DelSolMike's Avatar
Default Basemap problem or chipped ecu problem? Help needed asap!
Alright so I tried starting my car again today and it runs fine for about 10 seconds and then it starts idling very rough and and drops down to extremely low rpms. I only have a basemap for my hondata unit. I was thinking since I do need to get it to the shop to get the new block put in and to get the exhaust cut out welded up, could I put the stock ecu in and just keep it away from boost so it doesn't throw itself into limp mode? I figure that would be the safest thing for me to do right now. Any ideas? Thanks!
-Mike
Old Apr 22, 2006 | 08:15 PM
mrbsponge's Avatar
it all depends, what size injectors are you running? stock ecu wont idle big injectors. you running a 3 bar MAP, cause stock wont run one either. and no one will recommmend you drive your turbo car on a totally stock ECU.
your problem is probably just being a little too lean in the first couple columns
Old Apr 23, 2006 | 04:48 AM
DelSolMike's Avatar
Stock injectors and stock map.
mrflak0
May 2, 2010 10:02 PM
vietrob1037
Sep 17, 2009 03:58 PM
aggressivecivic
Jan 22, 2008 05:52 PM
DelSolMike
Apr 24, 2006 04:42 AM
Scean
Dec 9, 2004 07:23 AM
