What range of HP should I expect to have?
I have a GSR w/ JE pistons 9:8:1, eagle rods, arp headstuds, cometic, thermal exhaust, ctr intake cam, skunk2 manifold & cam gears, port matched the intake side of manifold, the head was shaved 3cm to be safe w/ boost........
Precision 880 injectors, fpr, venom fuel rail, walboro 255........
Garrett t3/t4 .70 a/r 57 trim .63 a/r, a obx manifold, greddy bov & running AEM.....
ok guys, I would really appreciate any info........i'm tuning soon so i'm just anxious to know..........
thanx in advance.......
Re: (Schister66)
i have a 7psi spring so i can use that for low boost, i 'm thinking more like 20psi for high boost...........i'm working on getting my dual mbc..........
Man U FTW
nice....i think on 7psi you could expect somewhere in the 250-260 range and at 20psi i think somewhere in the 370-390whp range, but its early in the morning and i'll probably edit this later.....
I post fake dyno charts
Re: (TypeGSR196)
i have a similar setup with a smaller turbo... tuned on crome...with those comp pistons you should be around 320whp @ 10psi reving to 9k... and 20-21 psi you should easily break 400whp... i tuned mine on 21psi and made 460whp...with ctr cams and stock sleeves...
