Question regarding larger TB
Old Apr 22, 2006 | 07:06 PM
Hybrid96EK's Avatar
Default Question regarding larger TB
I just put a 94 LS TB (60mm) on my boosted Z6... The idle readings went VERY rich (10:1), but the boost portion of the map seems fine. No leaks, nothing like that. What would cause the lower portion of the maps to richen up other then a loss of vac (changes map reading at idle)? Vac still holds strong at 21 at idle...
Old Apr 22, 2006 | 07:16 PM
abnaasefmb's Avatar
Default Re: Question regarding larger TB (Hybrid93Eg)
what r u tuning with? sounds like the tune is off.
Old Apr 22, 2006 | 07:18 PM
Hybrid96EK's Avatar
Default Re: Question regarding larger TB (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">what r u tuning with? sounds like the tune is off.</TD></TR></TABLE>
Crome Pro. Tune was dead on before I added this TB. Idled fine at 14.7:1.
Old Apr 22, 2006 | 07:27 PM
abnaasefmb's Avatar
well i dont know about swapping throttlebodies but you should just be able to adjust your low cam map and be good.
i once had an exhuast cam a degree or two off. when i noticed it and fixed it i had to tottlly redo my whole map. it funny how much one thing can effect your tune.
Old Apr 22, 2006 | 07:37 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">well i dont know about swapping throttlebodies but you should just be able to adjust your low cam map and be good.
i once had an exhuast cam a degree or two off. when i noticed it and fixed it i had to tottlly redo my whole map. it funny how much one thing can effect your tune. </TD></TR></TABLE>
No, see... I know HOW to correct the problem, I am asking if this is a common thing to see from a larger TB? I've never messed with larger TB other then stock and to see the readings richen up this much had me a little shocked...
Old Apr 22, 2006 | 07:39 PM
abnaasefmb's Avatar
yeah, i don't know. seems funny
Old Apr 22, 2006 | 08:09 PM
Jaker's Avatar
Did you have to swap over the TPS or is it the one that was OEM attached to the TB?
Old Apr 22, 2006 | 08:37 PM
Hybrid96EK's Avatar
Default Re: Question regarding larger TB (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">Did you have to swap over the TPS or is it the one that was OEM attached to the TB?</TD></TR></TABLE>
One attached to the stock LS TB. Didn't swap.
Old Apr 23, 2006 | 09:34 PM
Hybrid96EK's Avatar
Found the problem. Oring for the map sensor was missing. It was creating a pretty large vac leak. Even though the gauge still showed 21" at idle... I could cover up the whole tb and the car would still idle. Anyways, oring is in, problem is solved.
jonman27
Oct 22, 2010 01:25 PM
Race Egr
Apr 5, 2004 10:32 PM
