i need help picking a clutch for my lude
here is my set up i need help picking out a clutch
5 speed manual transmission with a Quaife LSD
o o Fully built bottom end with ROSS pistons, rings and crower rods
o All internals in the motor were replaced with new parts. (i.e. bearings, oil pump etc.) my head has a full ported and polished,with a 5 angle valve job and has Ferrea valves, springs, and retainers installed.
o Unorthodox Racing Crank, Alternator, etc. pulleys.
o New Turbonetics T3/T4 turbocharger with a Spearco intercooler, Racegate waste gate, Greddy blow off valves, map bypass valves, etc.
o Custom turbo headers and exhaust, with a 5Zigen Stainless steel muffler.
o MSD ignition and coil, magnacore wires.
o High output Bosch fuel pump & turbo boost controlled fuel pressure regulator
AEM EMS 30-1040 with wideband 02
Air/fuel ratio gauge
SPW boost gauge 7 color
SPW water temp gauge 7color
SPW oil press gauge 7color
https://honda-tech.com/zerothread?id=1601885
https://honda-tech.com/zerothread?id=1601929
https://honda-tech.com/zerothread?id=1577422
https://honda-tech.com/zerothread?id=1583605
https://honda-tech.com/zerothread?id=1583607
https://honda-tech.com/zerothread?id=1552232
https://honda-tech.com/zerothread?id=1552233
https://honda-tech.com/zerothread?id=1536328
How many times are you going to post this exact same thing?
Location: R.I.P Brian Arbogast...you will be missed, maryland, USA
Re: Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Ban.</TD></TR></TABLE>lol<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nikolai. »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1601885
How many times are you going to post this exact same thing?</TD></TR></TABLE>owned
Moderator in Chief
Re: i need help picking a clutch for my lude (h22_crx)
You gave us all this BS about your car but left out the important details - How much TORQUE do you need your clutch to hold? Knowing what color your gauges are is not relevant to picking out a clutch. What kind of clutch do you want?
Do you want something streetable, hardcore, on a budget, what? Theres about 50 clutches that will work. Clutchmasters, ACT, Exedy, etc. Any brand preference?
shermanyang
06-24-2005 10:10 AM
turbotk
05-28-2004 07:33 PM
GForceInteg
05-26-2003 09:46 AM
