Any constructive ideas wanted!!
Old Apr 22, 2006 | 06:11 PM
nudvl's Avatar
Default Any constructive ideas wanted!!
I have a 88 CRX dx that I've had for 2 yrs now. I'm converting from auto to manual. I plan on running a SOHC. My target HP is 350-400. I have so far a Z6 motor,Y8 intake mani.,log style turbo mani., and a 14B turbo. I will custom make a 2.5 in. down pipe w/ a 2.5 in. cat-back w/ either a testpipe or gutted cat. I want to be able to turn the motor in the 7k-8k rpm range which I think will be a problem with the 14B since it came off a 1st gen eclipse and it craps out at around 6k or so. The car will be a weekend cruiser and a track bruiser!! I plan to build the block dont know wether I should use a block guard or save more money and have it sleeved. Probley go with the sleeves. I want my crank balanced and micro-polished, and use ACL bearings. But how does that work? I have always understood that the crank bearings were different sizes. Can anyone explain that part? Do oversized pistons make a difference? Why? I plan to run like a 9-1 comp ratio. I will get a msd 6al ign. box, good wires, msd cap, msd coil, button, stuff like that as far as ign. goes. I was thinkin about endyn or hondata as far as management goes so I dont think Ill have any problems there. And of course good rods and pistions!!!! I have a cam gear and Ill probley get a ZEX cam or sumthing like that. I was thinkin about a JRC FMIC. I have a Walboro 255 hp pump and sum DSM 450 injectors but Im thinkin that I will need bigger injectors sumthing like 550's or bigger but how big? I will be runnin 93 pump gas and maybe sum cam2 but not often if at all!!! Are stock valve springs good enough or do I need to upgrade? Ill have the head freshend up, do sum port-matching and maybe sum polishing. What kind of turbo am I gonna have to run in order to turn the rpms and help make the HP that I wanna make? Can i get there usin a 14B(probley not) or a 16G?? If sum of this doesnt make any sense plaese tell me and I explain or make changes. And please keep ur answers and ideas simple Im new to the turbo game.
Old Apr 22, 2006 | 07:13 PM
delslo93's Avatar
Default Re: Any constructive ideas wanted!! (nudvl)
First off good job with sticking with the Single Cam 350-400 hp is gonna be hard to get though. To make 350-400 hp you will want at least a 3 inch downpipe and a 3 inch exhaust. You will also need a new fuel pump (255) and a 3 bar map sensor (gm 3 bar) and DSM450 cc injectors max out at about 300 hp so you'll need at least 550's to make 350hp but i would go bigger like 650cc injectors. A 14b will def. be too small for your hp goal so is a 16g. I would just get a nice t3/t4, something big like i have which is a 63 a/r 57 trim or bigger. You will want new springs and retainers and probably valves especially if u are getting a zex cam and revving to 8000 rpm. Also I would probably ditch the log manifold and get a nice equal length ram horn because though the log will give u better spool times, who needs that when you're trying to make 350-400 hp out of a d?
What management are you using? Are you gonna get dyno tuned?
hope that helps alittle....good luck
Old Apr 22, 2006 | 09:11 PM
nudvl's Avatar
ok it wont be hard to go to a 3in dp & exhaust. the 255 pump and GM 3 bar map I have. what turbine wheels give or get you more? sum more explaining on those would be nice! Thanks for the info!!!!!!!
Old Apr 22, 2006 | 09:32 PM
GS-R Civic's Avatar
Default Re: (nudvl)
makes me want to do something with my old motor that is sitting in my garage...
Old Apr 22, 2006 | 09:34 PM
ella94's Avatar
- oooh boy. You might end up spending to much. Can you not settle for 200-250 whp? Would be SOOO much cheapier and might realize its all the boost you need. Its still enough to break mid 12's.
- 3" dp at the least. straight pipe works, if you have smog try a high flow cat. do NOT gut the factory cat. 2.5" will not work for 350-400whp.
-Raising the rev limit should only be done on a street car to keep it in good powerband. Other than that, keep it as low as possible. Revs cause WAY more stress on the motor than boost. Revving to 9k when you have a fat powerband from 5k-8k with peak around 6500 or so, there is no point of a 9k rev.
- If youre shooting for 400whp on a d series, sleeves sound good. If you dont plan on sleeving it, and your motor is high milage, i would sujest boring it .5mm over to get a fresh cyclinder and help your new ring lands. Rods are a must have in a sohc build, as they are very weak. I guess what im saying is, 400whp on a sohc weekend hell raiser will require some good block work to ensure reliabilty. If you lower your goal some, rods/pistons will do plenty fine.
- Personally, i wouldnt bother with crank work. Save your coins. So many high hp builds, even on d series with no crankwork at all.
- Good and safe, cant go wrong there.
- Many will tell you stock ignition will work just fine. I perfer a digital 6AL myself as well. Hell, it cant hurt. While your at it, get 1-2 heat range colder plugs for added safety.
- No point of really buying that. Just have it dyno/street tuned by someone who has it. Unless you want the system in your car on a laptop to freak some people out, its expensive really.
- For sure.
- I personally have no idea about what cam would be good for d series boost. d15b jdm vtec cam? I have no idea honestly. Id sujest asking around and see what numbers people are making on there cams with boost.
- for 400whp, i sujest 750cc's. 450s wont do at all and 550s will have a higher duty cycle than what it really should have to ensure reliabilty IMO.
- If its only a weekend beat up car, might as well throw in a 2 dollar bottle of octane boost at autozone or wal mart. Will raise it to 100~ or so. Its safer and can be tuned to extract more whp if its on a strict diet of 100~octane rice.
- If you plan on moving up the rev limiter, no. If you get a cam thats not OEM, no. If you get a zex cam or whatever it might be ok, but the springs are made for the factory cams. Using more aggresive cams could be flirting with trouble.
- Hey, cant go wrong there. Also nice to make more whp at the same boost lvl.
- Honestly, Ive seen a lot of 300+whp figures using only a T3 junkyard turbo. The GT28R will work fine aswell. Im not awful sure about it but id keep asking around what turbo would have a killer powerband on a 8k rev motor. Or whatever your limit will be.
Old Apr 23, 2006 | 06:43 AM
nudvl's Avatar
lots of great info man!!!!!
the reason for the 350-400 HP range is for a couple of reasons
1- its a SOHC
2- a friend of mine has a srt-4 and he thinks he's KING of the streets
3-ITS A CRX W/ 350-400 HP FROM A D-UNIT!!!!!!!
I just got done reading a article on a Super 20G turbo from Hahn Racecraft Im goin to check into that but for real I wanna turn somewhere between 7k-8k rpms I dont wanna feel like Im driving around with half a LS motor under my hood
Old Apr 23, 2006 | 07:27 AM
delslo93's Avatar
Default Re: (nudvl)
i have basically the same build you want to have other than the sleeves. I have a precision SC34 turbo (pretty big for a single cam but it makes extremely good top end power with my head work), but at only 11psi I can pull like 2.5 car lengths on SRT-4's I also pulled about 2 car lengths on a WRX sti and I have a del sol which weighs more than your CRX. 350-400 hp will def. rip that SRT a new *** with your light car. Basically what I'm saying is you don't need 350-400 hp to beat a SRT-4
Old Apr 23, 2006 | 11:38 AM
nudvl's Avatar
r u usin a block guard? I want a turbo thats good through mid & high rpms!! my car is light so im gonna have trouble takin off. I plan to run a traction bar with a frount mount and all the poly bushings i can find.
Old Apr 23, 2006 | 03:48 PM
nudvl's Avatar
TTT
Mitsuzuki
Nov 5, 2007 12:12 PM
PINKS
Feb 12, 2006 05:13 PM
ZEX Man
Dec 2, 2004 02:02 PM
ApexiChild
Jul 29, 2004 12:52 PM
