Ramhorn Help@!
Old Apr 25, 2006 | 09:07 PM
Dc4turbo408's Avatar
Default Ramhorn Help@!
I installed my god damn Ramhorn today, and that **** was hella loud..... any got the same problem? should it be quiet?
Help me outttttttttttttttttttttttttttttt
Old Apr 25, 2006 | 09:14 PM
slowhonduh93's Avatar
huh??? why is it loud???.... explain later Mike
Old Apr 25, 2006 | 10:57 PM
Default Re: (slowhonduh93)
well i slaped that **** on today using the same stock exhaust gasket... it work fine with my old log manifold, but ever sinced i slaped on the Ramhorn.. That **** got pretty loud. I tightin everything down from dp to exhaust. My friend said it might be the gasket.. But I noticed when i install the manifold, i couldnt get like 2 bolts in causse the ramhorn was blocking it.
Can that be it?
Old Apr 26, 2006 | 03:28 AM
btotherizzle's Avatar
Default Re: (LsvtecBoi408)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsvtecBoi408 &raquo;</TD></TR><TR><TD CLASS="quote">well i slaped that **** on today using the same stock exhaust gasket... it work fine with my old log manifold, but ever sinced i slaped on the Ramhorn.. That **** got pretty loud. I tightin everything down from dp to exhaust. My friend said it might be the gasket.. But I noticed when i install the manifold, i couldnt get like 2 bolts in causse the ramhorn was blocking it.
Can that be it? </TD></TR></TABLE>
yes!
Old Apr 26, 2006 | 05:57 AM
if you couldn't get two bolts on the manifold... i means that exhaust gas is escaping from there... that is why its loud.... tighten all that **** up and you'll be fine... later Mike
Old Apr 26, 2006 | 08:15 AM
project dc2's Avatar
Default Re: (btotherizzle)
you prob didnt get the nuts on cylinder 1 and 4 cuz you need to si the manifold on the edge of the studs and slowly thread them in as you push in the manifold too. so basically the nuts hrea and sucks the manifold into the head. get the MR gasket copper gasket. **** works wonders
Old Apr 26, 2006 | 09:17 AM
Default Re: (project dc2)
U got some copper gasket? phil? Hit me up with a price playa. and i also need some new nuts. my **** is tooooooooooooo long.
Old Apr 27, 2006 | 08:08 AM
the copper gasket is 40$ i got one right now
the copper nuts are 1.05$ each i got those in stock too
Old Apr 27, 2006 | 08:14 AM
Mugencrxsir1's Avatar
I had to shave the top bolts down by almost half, yes #1 and #4 are a pain in the ***, but you will have to grind them down some and install those bolts first. Then install the rest of the bolts and tighten up the header evenly, that will make a big difference in sealing.
Old Apr 27, 2006 | 11:38 AM
Default Re: (Mugencrxsir1)
Thanks, I will do that...
marshman
Honda S2000
Feb 28, 2007 08:16 PM
BioXide02
Aug 21, 2005 08:45 PM
SIK IN DA HED
May 28, 2002 05:07 AM
Tanner
Apr 30, 2002 05:23 PM
LoudLude
Apr 14, 2002 12:22 PM
