QUICK ???? ON PISTONS AND....
Old Apr 23, 2006 | 08:32 PM
JLHDOHC's Avatar
Default QUICK ???? ON PISTONS AND....
just got my pistons in my darton sleeved block there wiseco pistons and there hitting the oil squirter what should I do.....
Modified by JLHDOHC at 10:41 AM 4/24/2006
Old Apr 24, 2006 | 09:41 AM
JLHDOHC's Avatar
Default Re: QUICK ???? ON PISTONS AND.... (JLHDOHC)
bumb..
Old Apr 24, 2006 | 11:16 AM
adseguy's Avatar
you can take out the oil squirters and plug them up. Forged pistons don't need oil squirters
Old Apr 24, 2006 | 03:00 PM
JLHDOHC's Avatar
Default Re: QUICK ???? ON PISTONS AND.... (adseguy)
What makes the forged pistons not need oil squirters compared to the cast pistons is it just because of cast and forged
Old Apr 24, 2006 | 06:04 PM
JLHDOHC's Avatar
anyone???
Old Apr 24, 2006 | 06:17 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLHDOHC &raquo;</TD></TR><TR><TD CLASS="quote">What makes the forged pistons not need oil squirter's compared to the cast pistons is it just because of cast and forged </TD></TR></TABLE>
the forged pistons run cooler and do not require the pistons oil squirter's when compared to the stock cast pistons.
BUT i would still use them anyway......they provide better lubrication to the piston pins and every little bit of piston cooling helps since boost likes to heat things up pretty good in the chambers.
also...you should read the instructions that came with your wiseco pistons. the piston skirt design requires you to bend/modify the piston oil squirter's to clear. and i think they want about .030-.035 clearance between the piston skirt and the squirter.
good luck
mitchell_2kSiR
Feb 4, 2010 04:01 AM
mitchell_2kSiR
Jul 29, 2008 08:28 AM
FuNkDrSpOt
Jul 29, 2006 12:21 PM
EITCP
Nov 1, 2005 09:48 AM
92TypeR
13
Feb 26, 2005 11:18 AM
