More JSRC questions-fpr with fmu?-timing stuff?
Is a 4.2 nose pulley on a gsr stock psi of about 6?
All other pulleys are stock.
Why does my idle bounce up and down if I advance the timing anymore than about 10 or so, but anything under 10 the idle is just fine.
I am using the fmu right now with stock fpr.
I beleive I am running rich, it always takes it a second to start up like its flooding.
It also is boggy up until about 5500 rpms where it must lean out some.
I have a b&m fpr that I would like to install so I can lower the fuel pressure a tad. Will this work or will it screw up how my fmu works because the stock fpr is a rise/rate fpr or some **** like that???
I do have a 255 walboro intake pump as well.
Thanks guys,
98civic94gsr
Also I searched fmu fpr and came up with 44 results in which I skimmed through and didn't really find a definite enough answer.
Thanks guys,
98civic94gsr
greyzone
11-14-2001 09:14 AM
