Bad Idle problem
Old Apr 26, 2006 | 06:21 AM
irocdaparty85's Avatar
Default Bad Idle problem
I have a 97 Turbo prelude. Since the recent temperature change, the lude has began to run lean, and hesitate. The idle at red lights and stop signs is completely gone. The car just won't idle once it's warmed up.
Could the problem be related to a bad O2 sensor on my AEM Wideband? I know it's linked into the p72 ecu. So could it have just gone bad and it's time to replace it?
Or any other help would be great. The car was running great since it was tuned about 7K miles ago.
Setup..
Rev-Hard Turbo Kit
T3/T4 Turbo .60ar
HKS SSQV
Tial 38mm wastegate 7psi Spring
Skunk2 Pro-Series Intake Manifold
Skunk2 Pro-Series 68mm Throttle Body
Hondata Intake Manifold Gasket
HKS 120mm Filter
RC Engineering 650cc Injectors
Walboro 255lph Fuel Pump
2.5" DownPipe
Full 3" Exhaust
Welded DumpPipe
Magnaflow 3" Oval Muffler
Hondata S200 W/ Boost, Datalogging &
all the goodies
P72 ECU
Old Apr 26, 2006 | 01:37 PM
Default Re: Bad Idle problem (irocdaparty85)
Anyone - any ideas? I'd like to have the problem fixed before anything else go's wrong
Old Apr 26, 2006 | 05:32 PM
HiProfile's Avatar
Either the WBo2, bad FITV, or has idle fuel pressure issues with the large pump. I'm assuming the 68mm TB has provisions for the FITV? If not, that is probably the issue. I'd assume its a bad WBo2 that runs off the maps when cold - maps tuned while warm and FITV closed. That would create the lean condition.
Old Apr 27, 2006 | 06:45 AM
Default Re: Bad Idle problem (HiProfile)
what exactly is a WBo2?
Old Apr 27, 2006 | 07:11 AM
nonvtecD's Avatar
WideBand o2 ...
slowhonduh93
Feb 1, 2007 02:23 PM
swapped95
Sep 17, 2006 12:34 AM
V-Thang
Feb 18, 2004 06:17 PM
crx1856
Jan 13, 2004 06:45 PM
_Shadow_
May 4, 2003 09:41 AM
