Fully built B20 Vtec
Old Apr 25, 2006 | 09:15 AM
godzhand's Avatar
Default Fully built B20 Vtec
I was searching around and found very little information on fully building a B20B for turbo. Money is going to be no option so is there anyone who can give me a link or point me in the right direction.
a few questions i have?
1.Dart Block or OEM B20B BLOCK
1.dart blocks do they come sleeved or is it not necessary?
2.If i were to sleeve the block for turbo whats the biggest bore i would want to do?
3.piston and rod combo?
4.which crank stock or aftermarket? if so which one?
5.should i just get a B20 stroker kit and which displacement would i be looking for max for turbo?
thank you guys in advance for your help...
Old Apr 25, 2006 | 10:08 AM
jdmhondacrx's Avatar
Default Re: Fully built B20 Vtec (godzhand)
sleeves is a need for b20 blocks if ur looking to boost alot.. then all u need are a good set of pistons and rods
Old Apr 25, 2006 | 11:56 AM
Chris22215's Avatar
Default Re: Fully built B20 Vtec (jdmhondacrx)
1. dart block if you've got the money, or just sleeve your block now
1. dart blocks are sleeved already
2. 84mm anything larger and you'll have headgasket trouble
3. anything other that srp and eagle. ie. Crower pro billet w/ cp pistons
4. stock crank, unless you want a stroker crank
5. you can go with a larger crank, but the stock one will me fine.
(i just realized that you've got two number 1s)
Old Apr 25, 2006 | 12:43 PM
Default Re: Fully built B20 Vtec (Chris22215)
hey i run benson sleeves pauter rods and arias pistons. 700 plus no problem
madcrx69
Sep 22, 2011 08:38 PM
C2K_TB_TEC
Jun 14, 2009 07:19 PM
lakai_19
May 21, 2007 02:25 PM
ACrite3404
Apr 22, 2006 03:43 PM
jdmcivic1999
Mar 7, 2005 08:10 AM
