17's on 400 whp SI??
Im gona be running a b16 tranny on my 400+whp SI, and someone said that I should look at getting 17' rims with some good/bigger tires to help get gearing/traction back, or something to that nature, is this true, I currently have 16' rims with azenis, should I stick with the 16's or go bigger?
1 Post
Negative. I have low 300's at the wheel and have had 15-17 inch wheels on my SI. The 17's spin worse than any of them because of the lack of sidewall. It's better for cornering traction but a stiffy is worse for straight line traction.
Buy slicks, I did and never looked back.
Re: (Jay_Sensing)
I run 15' 225/50/15 Drag Radials BFG. They grip real nice, you should run them on your set up. With 400whp, you cant get traction on azenis street tires in the first 3 gears....
Re: (JDM00SI)
azenis' have a really stiff sidewall too. theyre more directed towards road race/auto-x. from what i understand when you decrease air pressure you actually LOSE traction. the sidewalls are so stiff they cause the center of the tire to collapse and ride on the sidewalls/outsides.
Re: (JDM00SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI »</TD></TR><TR><TD CLASS="quote">I run 15' 225/50/15 Drag Radials BFG. They grip real nice, you should run them on your set up. With 400whp, you cant get traction on azenis street tires in the first 3 gears....</TD></TR></TABLE>
got them too. look for a drag radial for traction. you are kinda stuck with 15's from bfg. i havent been able to find a 16in drag radial that will fit on a honda.
i run the same 225/50/15's. its a little taller than stock which is good cause it helps your gearing a bit, atleast for the quarter. i still spin 1st and little of 2nd at the track with over 300whp
Re: (HighRevn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HighRevn »</TD></TR><TR><TD CLASS="quote">what about these
http://www.tirerack.com/tires/...ace=7</TD></TR></TABLE>
Those are the tires that come on the SRT-4 I believe..... not really a straight line traction tire but an all around good performer, I personally just dish out the money for BFG DR's. If you are putting down 400whp in a FWD car.....not really much to dramatically help in my opinion
Re: (slowteg550)
Yeah how do you guys run 225s on a lowered car? I would like to run the same BFGs but was wondering about the fit. I presently have the Azenis 205-50-15, and yeah I spin the s**t out of them. I put down about 370 or so.
Re: (Dialectic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dialectic »</TD></TR><TR><TD CLASS="quote">Yeah how do you guys run 225s on a lowered car? I would like to run the same BFGs but was wondering about the fit. I presently have the Azenis 205-50-15, and yeah I spin the s**t out of them. I put down about 370 or so.</TD></TR></TABLE>
I ran that same size azenis too and managed a 1.96 60 ft completely bald on a blown motor
Re: (96 GSR-T)
Most people will run 225 wide 15s that any any hope with grip.
The problem with 17s is the sidewall are soo small, they dont flex, which can *reduce* traction.
Stick to a 15" rim with super sticky 225 tires.
225 tire and traction > slammed civic on 22s
liam
B16SolMan
10-17-2008 07:46 AM
EMphaticONE
17
12-15-2004 06:45 AM
